Injector or Fuel pulsation dampner (pic)
Ok...well i finally got to where I was going. Boy this was fun. Anyway, what do yout think that is leaking? The other injector (notshown) is clean as can be, but this one....well see for youself...
Now...do you think its the injector itself or is the FPD "drippin" down on the injector...
Im really starting to hate this ****......
Yeah, I don't see any leaks around your injectors or your FPD. Your oil injector looks a little dirty, though... I'd replace your FPD while you're in there just as preventive maintenance.
Paul
Paul
Dude,
There is an easy way to test this. Just go to the little diagnostic box on the drivers side of the engine compartment. With the car off just take a piece of wire and "jump" the terminal labeled F/P (this is the fuel pump) to ground. Then go into the car and turn the key to the on position. This will turn on the fuel pump. Now you can check for the leak in a real world situation!
ok..now im confused.. If thats not an Fuel injector what is it. Where the hell are my injectors then?
And thanks for the idea M_Snoby. I guess I have no alternative then to do that. However Most of my fuel lines (i think) came out with the solenoid rack, the bigger ones anyway. So I dont think that any pressure will be built up... ::shrug::
Trending Topics
Originally posted by JONSKI
Talk about multitalented! Mechanic, Photographer, and now photoshop sk1llz?! DAYM!
and it was Photostudio 2000 THANKYOUVERYMUCH Heh
What's the part # for FPD? Thanks
Ok, i circled in your photo where the injectors are. Dude you need to download the shop manual off of the web! It will tell you alot of the stuff you need.
http://iluvmyrx7.com/Technical_Info/...ice_manual.htm
check out the attached picture
fuel pulsation dampener- n3a2-180-20
they will tell you to buy the o-ring with it, but i did and mine came with one already attatched. if you buy one and it doesnt come with the o-ring, let me know. i have an extra.
It's never fast enough...
I bet you Love your FD right about now, don't you?
Believe us, if you survive this, you can do almost anything to it.
oh yeah guys... while the big picture is up there, i was wondering: is there any o-ring or gasket seal that goes between the oil injector metal ring and the engine block? and when you are putting it back in, is it necessary to line up the nipple on the ring with one of the holes on the bolt? thanks in advance.
imitek
Aug 28, 2015 05:28 PM
82streetracer
Aug 23, 2015 09:28 AM
