vacuum hose replacing....
Old Dec 24, 2001 | 09:51 PM
RX-7 GT's Avatar
HyperREV.com
well it was on k2rd's site. but, it's gone. could someone please list what sizes, and how much of silicon vacuum hose i need? want to do this pretty soon when the engine arrrives.
Old Dec 24, 2001 | 09:56 PM
Forseti's Avatar
Vacuum Hoses.
Yeah I've been looking for this too. Some performance shops sell kits, but I'd rather buy the hosing, it's always nice to have some extra around.
Cheers
/F.
Old Dec 24, 2001 | 11:01 PM
RETed's Avatar
Sorry about that, the info is being moved.&nbsp Look for a new site in the new year in a couple weeks...
Right now, get 30' of the 3mm/4mm, 10' of the 6mm, 2' of the 10mm (this is for the brake booster if you're going to replace it).
This is primarily for 1986-1988 Zenki FC turbos...
The 1989-1991 Kouki turbos run a little more hose due to the wategate solenoid control.
-Ted
Old Dec 24, 2001 | 11:07 PM
RX-7 GT's Avatar
HyperREV.com
cool thanks ted
Old Dec 25, 2001 | 12:03 PM
takerwolf's Avatar
I was pretty sure that I checked and some of the hoses like the bac valve to intercooler were 12mm, or was I wrong? Also, I replaced the brake booster hose and after driving noticed it was completely collapsed and flat so I put the factory hose back on. If you put something in the middle of the hose would that fix that problem?
Old Dec 25, 2001 | 01:36 PM
Forseti's Avatar
Talking hitme99
Hey Ted,
Thanks for the information. Out of curiousity, how much extra hose is needed for the 89-91 TIIs? (And which diameter hose)
Thanks a lot!
/F.
Old Dec 25, 2001 | 06:59 PM
RETed's Avatar
You could be right.&nbsp I've got a GReddy BOV kit installed, and I couldn't use the stock sized hose under there.&nbsp I went the expensive route and bought a SAMCO 5/8" to 3/4" reducer for $35(!!!) to replace this hose, since the GReddy pipe adapter was slightly larger than 5/8"!&nbsp So I guess the 5/8" ID equivalent would work in this case for stock set-up, but who sells 12mm "vacuum" silicone hose?
-Ted
Old Dec 25, 2001 | 07:00 PM
RETed's Avatar
Re: hitme99
I'd say another couple (2) feet of 3mm/4mm hose should cover it.&nbsp Remember, my estimates are on the long side, so you're going to get some leftover...
-Ted
ls1swap
Jun 3, 2024 03:25 PM
rattlehead
Sep 25, 2015 10:55 PM
ZacMan
Sep 19, 2015 09:20 PM
localized
Sep 16, 2015 12:18 AM
