Question for all you motor swappers out there
I've just got a replacement motor for my 87TII today and it looks like a 89 + motor.
First and foremost, is it compatable, block only (I'm swapping everything else including injectors)
The new motor has an electric OMP, obviously have to change it.
BUT.Is the 87 turbo manifold compatible with the 89 block? I'm pretty sure the 89 turbo won't bolt up to the 87 exaust. I've heard the compression is higher on the later models is this true and will it cause me any problems? Also heard the knock sensor is in a different spot, will it still be compatible and/or swappable with the 87 sensor? Will the 87 intake manifolds bolt up? Will I need to swap the flywheel from the 87?
If I think of anything else I'll repost later. Most of these things I could check myself but I don't want to take it apart if I have to return it.
Re: Question for all you motor swappers out there
The 87 manifolds won't match up with the 89 ports, and you must keep the 89 flywheel or else the motor will be out of balance. The higher compression shouldn't be a big concern. The 89 turbo will bolt right up to your exhaust.
You need to use the flywheel and front counterweight that came with this motor, they are weighted different due to the diference in rotors. IF you mess this up your motor will vibrate and wear out early. Leave the flywheel and front weight on it that are on it now. THe fl;ywheels are the same diameter, same clutch parts and stuf, just different balanced.
Originally posted by hypntyz7
The intake should bolt up, but why. Ive heard that the runners on the 89+ are a bit bigger, this means youd wanna use those. Also, the lower manifold is a real pain, plus there is a coolant o-ring inside that is hard to get seated peoperly when replacing it. I would NOT fool with this unless I had to. Some of the electronics on the engine might be slightly different as far as plugs, so just swap those out individually one at a time with parts from your old block. IF it were me, Id put your old throttle body on the newer upper intake, as those runners *might* be larger also, but check it out first. Id leave the lower mani. alone. Also use the spec/89+ IC, I think they have a slightly better flow rate. Just use your injectors and wiring and electronics and you'll do fine. The engine might struggle to idle at first because of the lighter weight rotors(89+ dont idle well when they're in an 89+ car anyway, much less a 87 computer that doesnt know about the difference) but you should be able to tune it fairly decent.
Thanks for the info Dave, I learned something else today.
So what you'd want to do is to use your old throttle body on the newer upper intake and leave everything else alone, right? Simple enough...
Thanks for the input.
I'm not interested in power gains and/or taking the trouble of tuning it to run right with an 89 setup since as soon as it's running well I'm selling. It seems to me that the best course of action is to get the proper 87 block and be done with it. Also I want a car that will pass emissions and a J spec long block simply doesn't qualify.
However if someone wants to buy the engine AND car to go through the hassle themselves, feel free to email me.
This summer I put lots of parts into it.
Fast 14 16 inch rims (multispoke)
Rebuilt kevlar clutch
injectors cleaned and flowed
HKS supermegaflow intake
new rotors and sticky pads all around, painted calipers
new sunroof panel and guide wire, works fine but not yet worn in
new wires, plugs
alarm with keyless entry
Red line tranny fluid
sparco pedals
All season car cover, still in box, car stored in doors
The car had an FCD and full RB exhaust when I bought it. The car is blck with red interior, honestly it grows on you. I have the stock cat with adapters welded to it and it easily passed emmisions on a dying engine in 2000 with the air pump running.
The seats are sunfaded without tears, a couple interior pieces are cracked, not the radio bezel. The tint is 13 years old and looks it. 5 speed with all power options. The body is in good shape with a very small rust spot over each rear wheelwell and some small door dings, there is some under body rust. The transmission shifts great. I bought the car 3 years ago and have put 3000 kms on it, now has 155000. The tires are at about 75%, but are entry level tires. All the bells and whistles work. I have a spare ECU and stock wheels, these would come with the car preferably. I have lost patience with the project and would like to see it gone. Any offer around 7000 CDN takes it.
If not I'll go with option 1 and rebuild then sell, I'd be more than happy to field offers for this case as well.
Thanks again
Andy
new wires, plugs
sparco pedals
Thanks again
Andy
Trending Topics
Skeese
65
Mar 28, 2017 03:30 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
