Evans Cooling Systems!!!!!!!
Old Nov 10, 2001 | 11:45 AM
crispeed's Avatar
'Tuna'
Anyone in here using or tried the Evans Coolant in their rx-7?
check out>>>www.evanscooling.com
Seems like some good!
crispeed
Old Nov 10, 2001 | 02:05 PM
David Hu$tlerhoff's Avatar
is sounds really good, i would like to know too if someone has experience with it
Old Nov 10, 2001 | 02:56 PM
Poweraxel's Avatar
Re: Evans Cooling Systems!!!!!!!
"Meloco" and I run that stuff on our cars..best **** out there
Rob at pineappleracing.com got us hooked on it
Steve
Old Nov 10, 2001 | 05:05 PM
Node's Avatar
hows the cost of that NPG cost over normal coolant
Old Nov 10, 2001 | 05:15 PM
pp13bnos's Avatar
Pineapple Racer
The stuff is great. I was one of the very first people to actually use it through Pineapple Racing. (I'm his test subject alot of times.) As far as costs go, i think its $20+shipping.
I beleive that Rob won't warrenty a 3rd gen motor without this stuff running in the car. CJ
Old Nov 10, 2001 | 09:11 PM
crispeed's Avatar
'Tuna'
Seems like it's very good! It should really help 3rd gens keep cool and run a lot better.
crispeed
Old Nov 11, 2001 | 06:18 AM
soul assassin's Avatar
GTR eater
so pineapple racing sells it? how many gallons would ya need to fill the car up? am i reading it right you need no water? how does it do in the winter?
Old Nov 11, 2001 | 08:20 AM
pp13bnos's Avatar
Pineapple Racer
The only bad thing about the stuff is, it does'nt like to be contaminated with anything. No water or old coolant.
Its great for winter, because instead of expanding like water/coolant does, Evans shrinks.
I run it in my 3rd gen. This elimates the ast splitting, and the radiator from exploding. After all, it is a 0 psi system.
If you want to order some stuff contact Rob at 503-233-3878, just tell him that i sent ya, and he should give you a pretty good deal.
CJ
Old Nov 11, 2001 | 05:17 PM
GTR eater
so what is the best way to flush the system before adding this stuff?
Old Nov 11, 2001 | 06:59 PM
Blake's Avatar
Evans NPG coolant is not compatible with normal coolant and contamination with water should be minimized. Simply draining and flushing the system is not enough. Rob recommends that you first drain and flush with water (don't forget to drain the block and the heater core!), then put in Sierra coolant straight, drive the car around with the heat on (to circulate the Sierra through the heater core) until it's fully warmed up and then drain it. Sierra will absorb most all of the water and is actually compatible with the Evans NPG. You might want to do this twice. Then fill'er up with Evans and you're set for the next 100,000+ miles Alternatively, you could get a shop that does AC service to apply a strong vacuum to the cooling system, which will make any residual moisture vaporize.
Some of the cool features of Evans NPG are (1) no water means no corrosion, thus no need to flush and refill every year (it's a lifetime product), (2) it works great a zero pressure (370 degree boiling point), (3) it remains liquid until 70 degrees below zero and shrinks instead of expanding, and never freezes (just turns slushy), (4) it does not nucleate boil, so heat transfer is much better than conventional coolant (typically you can run 2 degrees more spark advance, for more power). And when you drain the NPG for other reasons (swaping engine, etc.), you just put it right back in when you're done.
Rob says that the stock cooling system components are just fine, provided everything is clean and maintained (no gunk in radiator, new thermostat, etc). Rob also offers a money back guarantee, which he has only had to honor once (and the returned coolant was extremely contaminated, which indicated the customer didn't follow instructions). I believe he sells it for $26 per gallon, or $24 per gallon for 4 gallons or more. Yes, it costs quite a bit, but for what it provides, it's a bargain! $60 for coolant vs. $500+ for a high-performance aluminum radiator?
Old Nov 11, 2001 | 08:20 PM
pp13bnos's Avatar
Pineapple Racer
Blake, you said it better than i ever could have. CJ
Old Nov 11, 2001 | 09:44 PM
Node's Avatar
would there be any performance gain over stock radiator w/ evans and upgraded radiator w/ evans?
Old Nov 12, 2001 | 05:15 AM
maxcooper's Avatar
WWFSMD
What components need to be changed to run the coolant in an FD? For instance, what cap do you use, and do you run an AST? I understand the flushing instructions, but I need to know if I need to get any parts.
This looks like a very cool product (pun intended)!
Thanks,
-Max
Old Nov 12, 2001 | 08:56 AM
pp13bnos's Avatar
Pineapple Racer
I'm currently using the stock ast, and radiator. All i did was drain the motor/radiator as best i could. Then, i put in the Seirra, drove it for about 50 miles (Over a couple days.) Drained it again. Then installed the evans. For a 0 psi cap, all you have to do is remove the little o ring on the radaitor cap. Don't forget to take a vacuum, and suck out all of the old coolant out of the over flow bottle. CJ
Old Nov 12, 2001 | 12:55 PM
BOOSTD 7's Avatar
Persona non grata
Hmmm, I've read about their stuff before. But I thought that you had to have their radiator and other hardware to use it. So you're saying that I could use it with my Fluidyne radiator? I assume they provide a 0 psi radiator cap?
If I don't need a new radiator, I'll probably go with their stuff when I get my new engine ... since the system is already drained.
Old Nov 12, 2001 | 02:17 PM
Red Rotary Rocket's Avatar
The timing of this thread couldn't be more perfect. It just so happens that I'm due for my anual coolant replacement, and I have been thinking about giving the Evans NPG a try.
Question: Those of you who are using it, what should I expect to see on my temp gauge? Lower temps, same temps, or higher temps? It wasn't quite clear to me when I read the Evans website. They say that the NPG doesn't absorb as much heat as water in liquid form, but since it has a higher boiling point, local boiling is minimized, which greatly aids in heat transfer. I guess it seems to me that if you are removing more heat from the engine, that heat has to go somewhere, so your coolant temps should be slightly higher....but that's just a guess. I want to hear from those who actually use the stuff.
Anyone care to comment on how their temperature readings have changed since using the NPG?
Old Nov 12, 2001 | 05:30 PM
pp13bnos's Avatar
Pineapple Racer
Sorry, it does'nt come with one. To make a 0 psi radiator cap, all you have to do is remove the little rubber seal, on the bottom of the cap.
As for readings, it stays just the same. However, a friend of mine who is running a Streetport/non seq./E6k, says that its about 5-10* cooler after a hard run vs having the normal coolant mix with water wetter.
The stuff heats up so much faster though, its amazing.
CJ
Old Nov 12, 2001 | 08:19 PM
Mr rx-7 tt's Avatar
rotary sensei
I always run a water pump lubricant....I wonder if you can or if it is needed..??BTW: What is "sierra"..?
Old Nov 12, 2001 | 08:34 PM
pp13bnos's Avatar
Pineapple Racer
Seirra is just anouther coolant that is compatable with Evans. CJ
Old Nov 13, 2001 | 02:17 AM
Blake's Avatar
Yeah, Sierra is that "pet friendly" alternative coolant, which like Evans is propylene glycol (PG) based, instead of ethylene glycol (EG) as found in conventional coolants. Evans is Non-aquious Propylene Glycol (NPG), which means it doesn't like water, but Sierra, on the other hand, loves water. This means you can flush out the system with water, drain, add straight Sierra, drive around for awhile, drain, and add Evans. This gets you from EG to PG to NPG with minimal contamination.
Old Nov 13, 2001 | 02:27 AM
Blake's Avatar
Evans has always insisted that special equipement is required, like a new water pump, radiator, and so forth. Not coincidentally, they happen to sell this specail hardware for most boinger applications. While it may or may not be true for most typical boingers, Rob has determined that it is a drop-in product for rotaries, provided the cooling system is clean and the product is not contaminated with water or old conventional coolant. Rob runs it in both of his REPUs, the GT2 race car, and has many satisfied customers running Evans, so I defer to his judgement as usual BTW, they recently came out with a slightly thinner formulation called NPG+, intended for street applications. Same price, same performance, just more compatible with stock hardware.
Old Nov 13, 2001 | 04:42 AM
Node's Avatar
anyone
Old Nov 13, 2001 | 11:56 AM
Blake's Avatar
Perhaps, but not necessarily. A bigger radiator has (ideally) a better ability to reject heat, but you really don't need anything larger than whatever is required to do the job in the worst-case scenario (racing, driving up a steep grade in a high gear with AC on, or whatever). Since the Evans coolant does a better job, people are finding the stock radiator is more than adequate for most situations. However, bigger radiators are not detrimental, and they look really cool! Really, if just comes down to "am I overtaxing my radiator, or am I overtaxing my coolant?" The proper approach, IMHO, is to solve to coolant overtaxing issue definatively before tackling the radiator issue. You might need both, but perhaps not.
Old Nov 13, 2001 | 12:29 PM
BOOSTD 7's Avatar
Persona non grata
I'm sold, I'm going to use this stuff in my new engine ... telling me that it will work with the cooling hardware I have now was the big thing.
