Took my 12a turbo for a ride today not fun:( Need major help!!!!
Old Apr 30, 2004 | 01:26 PM
seanrot's Avatar
Always waiting for parts!
I got the turbo install completed last night but since I have a staight pipe into a glasspack thought it best to hold off on the testdrive at 11 pm in a residential area.
So got up this morning around 11 and took her for a test drive. Things didnt go as I wanted. Go figure at least it started
Need some help.
She runs good till the boost hits about 3000rpms, then she back fires to all hell and back, I mean loud duck for cover backfires. Running too rich what you think?
What should I run the timing on a turbo 12a? The distributer is locked in advance position. I tried moving it a little at a time and test driving, no luck there.
Any ideas on what to look for?
Old Apr 30, 2004 | 01:37 PM
some kind of fuel problem....
Whats your fuel setup?
Old Apr 30, 2004 | 01:48 PM
it could be starving for fuel.... like boost is pushing it back through the carb.... or pump is pushing too much.... play with your regulator....
Old Apr 30, 2004 | 01:49 PM
seanrot's Avatar
GSL SE fuel pump and mallory rising rate regulator set at 6 psi
Old Apr 30, 2004 | 01:57 PM
web777's Avatar
What kind of carb are you running?
Old Apr 30, 2004 | 02:15 PM
web777's Avatar
I looked at your other post and it looks like you are running a Weber. You're most likely running real lean when boosting. Also put you dizzy back to the stock timing and see how it does.
Old Apr 30, 2004 | 03:14 PM
seanrot's Avatar
I thought backfires were a sign of running rich?
Old Apr 30, 2004 | 03:21 PM
web777's Avatar
It can be both. The rich back fire is a little muffled. Does your car accelerate faster when it starts to boost?
Old Apr 30, 2004 | 03:30 PM
seanrot's Avatar
nope, she is boggin out
seanrot's Avatar
ggggrrrrrrrr dp
Old Apr 30, 2004 | 04:15 PM
well, get rid of the glass pack for one, theyre more restrictive than people think. but probably nothing to do with the backfire, also i noticed youre blowing through the carb-correct? if so is the carb built for this application
? if not that could be part of the problem. also- youre ignition is distributer with vacum advance no? so check youre vac line to the dist -it may be in the wrong place -let us know what happens.
Old Apr 30, 2004 | 04:24 PM
fatboy7's Avatar
Got Boost?
If you want to find out what the problem is without blowing up your motor, I suggest you invest in some diagonostic equipment.
I'd recomend a fuel pressure gauge, an oxygen sensor (I strongly suggest a WB, but a NB is better than nothing), and perhaps an EGT.
Old Apr 30, 2004 | 04:40 PM
Oni-kyan's Avatar
5one5innovations.com
If Robert from Rotary Shack was alowed on this forum, he would have helped ya!
Old Apr 30, 2004 | 05:10 PM
web777's Avatar
OK, You're running lean. You need to jet up. Forced induction requires a lot more fuel!
Old Apr 30, 2004 | 05:17 PM
mwatson184's Avatar
holley guy
Where is your boost reference line for your regulator coming from?
If you have a fuel pressure gauge and a hand pump then make sure that fuel pressure is rising as pressure increases, you could have a faulty diaphram in the fpr.
Marques
Old Apr 30, 2004 | 05:36 PM
Junia's Avatar
Uchinanchu
why isn't he allowed on this forum??
Old Apr 30, 2004 | 06:57 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
yeah, What?
Old Apr 30, 2004 | 06:59 PM
hornbm's Avatar
FD > FB > FC
good question
Old Apr 30, 2004 | 07:57 PM
FB II's Avatar
it's probably because i'm fat.
Old Apr 30, 2004 | 08:05 PM
hiboost7's Avatar
i agree, i also think you are running lean....when boost kicks in you have no fuel to feed it, therefore engine dies down (bogs) jet up, and get a fuel pressure gauge and check your pressure and make sure its rising with boost levels, if not ditch that crappy fuel regulator that replaces the best eva
Old Apr 30, 2004 | 08:31 PM
Directfreak's Avatar
I am a Jeeper Now.
Also make sure the boost reference line for the FPR only sees boost - NOT Vacuum.
Old Apr 30, 2004 | 09:21 PM
Drj419's Avatar
yup ur running lean if ur bogging. But hey play around with ur tuning ull prolly fix the prob that way
Old Apr 30, 2004 | 09:49 PM
seanrot's Avatar
Do to the lack of exhaust at this time, this is a loud MF... I will be postponing any tuning till I finish that.
This is what I have for an exhaust, it damn loud.
My FPR is getting its signal from the carb hat as well as my boost guage. It doesnt show vacuum at all.
Time to go buy some more jets
Old Apr 30, 2004 | 10:40 PM
evita's Avatar
6 psi? Seems like too much fuel pressure to me. I could be wrong.
Old Apr 30, 2004 | 10:43 PM
9d7gst's Avatar
Boss**"You scare customer"
What kind of spark plugs? I know going colder in turbo apps is allways better. Also spark gap can make a big diff in pistion engines. Mabey different because the plug isnt in the chamber but worth a try.
