Weber IDA CARB HELP "VIDEO inside" fun to watch
Old Apr 18, 2004 | 02:25 PM
seanrot's Avatar
Always waiting for parts!
Weber IDA CARB HELP "VIDEO inside" kinda fun to watch
This is a repost of a thread that Im not getting much action on. I made a little movie of it.
movie link
16.4 mb file sit back and relax
click on it and save to your computer.. Sorry its a Quicktime product..
There is no muffler on the car so the video is quite loud!!! just a warning
OK I have a Weber 48 IDA following specs
Venturies 37 mm
Main Jet 180
Air Jet 160
needle seet 3.5 glass ball
Float turbo prepped filled with foam and sealed
0 bypass plug
Fuel pressure is at 4 on my summit (god only knows how accurate) guage
Enigne porting is stock
Heres what is happening. She idles good, runs up through the rpms great no problem. but when you stop to coast say 3000 rpm she buck and grumbles doesnt matter what rpm you stop and coast at, she complains.
I reset the float level to the stock settings per the haynes manual, but I think the float is heavier now with the foam, so the fuel level in the carb maybe too high. Could this be the problem? Does anyone have a reference point on were the fuel level should be in the carb itself?
Previous thread
Old Apr 18, 2004 | 03:09 PM
seanrot's Avatar
Comments are welcome:D
Please excuse the mess its a work in the progress
Cant find parts for this turbo, so I'm forced to fabricate the stuff myself. Like the wastegate dump tube?
GSL-SE oil cooler on a GSL
Feel free to make comments just TRY to be nice
Old Apr 18, 2004 | 03:36 PM
CarlRx7's Avatar
sweet setup man. looks good so far. my car does the same thing!! tried different fuel pressures from 2-6 same crap! it used to purr at idle.!. i got a new intake - motor gasket im gonna throw on there tommarow, ill keep you updated.
do you have an a/f meter intalled?
Carl.
p.s. where did you get that -an fitting that hooks on your carb and wut size is it.?
Old Apr 18, 2004 | 03:50 PM
seanrot's Avatar
Thanks
aircooled.net for the fitting heres the link..
http://www.aircooled.net/new-bin/cat...t2=FS&perpage=
-6 an
I dont have a af meter at this time maybe in the future.
Old Apr 18, 2004 | 06:23 PM
FB II's Avatar
that wastegate dump is gonna be loud. HELL YEA!
Old Apr 18, 2004 | 10:17 PM
seanrot's Avatar
Yeah, I think it will be a little suprise to whomever is next to it when it opens. hopefully they are looking at my tail lights by then
Old Apr 19, 2004 | 05:54 AM
Fd3BOOST's Avatar
Recovering Milkaholic
Looks nice Sean, where in Maryland are you?
Old Apr 19, 2004 | 05:26 PM
seanrot's Avatar
Andrews AFB, for the time being
Old Apr 19, 2004 | 06:51 PM
Directfreak's Avatar
I am a Jeeper Now.
Looks great!!
Love the Directfire bracket
Old Apr 19, 2004 | 07:18 PM
seanrot's Avatar
Thanks DF
Old Apr 19, 2004 | 10:10 PM
CarlRx7's Avatar
wuts your afsc seanrot?
<---COM/NAV c-17
Old Apr 20, 2004 | 06:16 AM
seanrot's Avatar
<---COM/NAV c-17
<--- Transportation/ the guys that load your a/c
w/cargo and passengers aerial porter
You at Charleston? Went through there flying space a once. Funny, on a C-17..
Old Apr 20, 2004 | 07:08 AM
deeman111's Avatar
I have the same sort of problem with my 12a Bridgeport.
Idles fine, but when it revs to about 3krpm the motor shakes like buggery and it goes all crap.... the rest of the rev range is fine. When driving it cant hold a steady cruise between 3 and 4k rpm.. just jumps and bunnyhops and burps and farts etc, it all started when i change the needle and seat. I believe its to do with the float level because i had a play and reduced the kickback slightly by playing witht he level. I had the problem where the level was too low, i starved fuel at WOT, too high.. it bucks and runs like ****... still cant find the happy medium
Fuel pressure doesnt help in anyway either.
Anyone got any suggestions???
Maybe ill just take it to a carby tuner
-James
Old Apr 20, 2004 | 07:34 AM
seanrot's Avatar
I called jay cee ent. the place where I got my needle and seat. I believe its a float adjustment problem too. I asked him if the float should be adjusted to the specs in the haynes manual. He told me its going to be trial and error. there needles are a touch longer than stock ones. If the carb is flooding, which i believe mine is to adjust the float .001 till it stops. When its correctly set I should be able to push on the float through the little hole between the jets and get fuel to surge into the barrels with a little touch. Sounds like its going to be a long weekend .001 inch at a time.
I was also thinking about doing this for more fuel bowl capacity its supposed to be a 20.8% increase
You can find more info on that here vw trends
Old Apr 21, 2004 | 03:55 PM
CarlRx7's Avatar
Lightbulb
any luck yet on finding the problem, i still haven't changed my gasket yet, as id have to drain the coolant and blah blah balh, dont got the money right now.
Carl.
Old Sep 22, 2004 | 04:12 PM
CarlRx7's Avatar
bumpity bump.. can you send me that video? link is down.
carl.
Old Sep 22, 2004 | 07:37 PM
coldy13's Avatar
Yeah, shutup kid.
I'm almost sure the problem is caused by running too rich while crusing. When I had 180 jets in mine, it would cruise great, but would detonate under 10psi. Now I'm using a 235 jet and it runs great under boost, no detonation up to 17psi, but sputters and bucks when crusing at 60+mph, under that it cruises great.
Old Sep 22, 2004 | 08:21 PM
CarlRx7's Avatar
he PMed me, said he found a peice of grass in the idle circuit, cleaned it out, and now he is good to go..
i wish that would fix my problem.
carl.
The1Sun
Sep 15, 2015 04:45 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
