How I made my TID
Old Oct 11, 2001 | 09:31 PM
TonyTurboII's Avatar
Glock Lover
How I made my TID
Ok, heres the write up on my TID mod. I also open vented my BOV at the same time, so they are incorporated in the instructions. This is only for use with an aftermarket intake.
Parts list:
3in. to 2 in. rubber reducer - $7.48
3in. rubber elbow - $10.92
plastic check valve - about $6.00
1in. to 1/2in. hose type reducer - $.50
2 ft of 5/8in rubber hose - ?
Okay here we go.
Ok, first things first. This thing barely fits around my J-spec air pump. The pump is about 1/2 the size of my american one. So ditch it or find a solution.
First, remove the original TID. On the rubber elbow, cut off one of the flared ends. Then, using a screwdriver, poke a hole in the elbow, by the vaccum line that goes into the old TID. Dont make the hole big enough to be noticable. It should be hard to see, after all you dont want air getting in there. You can see where it goes in in the first pic. It is now ready to be installed. Put the now assembled elbow with reducer onto the turbo. Dont tighten it until all parts are in place, cause they will need to be moved around to make it all fit. Put the vaccum line into the hole you poked. You can now attach your AFM, and intake. The rubber flange on the elbow will be a little bit bigger than the AFM, but it can be tightened down to fit. Check around the tube to make sure nothing is going to interfere. Youre done.
Now with the BOV. Take the check valve, and insert the 1in to 1/2in threaded adapter in the blow through side. Use teflon tape. Use rubber hosing into to attach it to the BOV. Tighted down with clamps. Pic 3 is a good look at all this.
Finito!
Any questions?
Old Oct 11, 2001 | 09:33 PM
Glock Lover
I forgot to mention I took this time to replace the 90 degree elbow in pic 4 that is between the BOV and the intercooler piping. Mine was very hard. I also ran hoseing from my air pump tp the nipple on my filter adapter.
Old Oct 11, 2001 | 10:40 PM
Chris Ng's Avatar
I'm with stupid -----^
That vac line you have connected to the TID with the white plastic barb, was that originally the line that had the silver check valve on it? (There are 2 hoses that originally connect to the stock TID.. the outlet for the bov and the line withthe checkvalve)
If you, you're going to need to put that checkvalve back in.. the hose is connected to the oil filler neck and is used as a part of the crankcase ventilation system.. it's a one way checkvalve that allows pressure to escape from the crankcase but not enter it..
Old Oct 11, 2001 | 10:47 PM
Question stupid
This may sound very very stupid but what does TID stand for?
Old Oct 11, 2001 | 10:57 PM
Erik's Avatar
Best of both worlds
Re: stupid
i think it stands for Turbo Inlet Duct or something like that
and i mean sound stupid here...but what does it actually do? i don't really know whats going on in the pictures
Old Oct 11, 2001 | 11:02 PM
Glock Lover
What checkvalve Ill have to go look. Is it in the line?
Old Oct 11, 2001 | 11:06 PM
Glock Lover
Re: Re: stupid
Its not a dumb question for someone who is unfamiliar with the turbos. Its the rubber tube between the airbox and the turbo. Its the same idea behind intake tube on the NA. Its basically a curvy old piece of ****. Make it bigger, lessen the curves, and you get more hp.
Old Oct 11, 2001 | 11:25 PM
Erik's Avatar
Best of both worlds
ahhhh, ok yeah i see it now
did you get your car running right?
Old Oct 12, 2001 | 12:18 AM
Glock Lover
Not yet. I need a rotary expert chained up in my garage.
Old Oct 12, 2001 | 03:36 PM
Glock Lover
Up like an erection.
Old Oct 14, 2001 | 09:03 AM
Josepi's Avatar
Despise Enmity
Pulled off the factory TID yesterday. @ the 2.5 inch end, the tube is hard as a brick. At the end that would mount to the MAF (AFM whatever) its a nice soft rubber. I'm wondering if some of the bucking I am experiencing can be caused by a lil air leak due to the impossible task of making sure the lower end is attached to the turbo. Going to be pulling the car into the garage today to check out my grounds; if anything helps i'll post it
joel(PA)
Oct 4, 2015 06:07 PM
Sh00bs
Oct 1, 2015 11:57 PM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
