avcr - what bar map sensor?
Old Sep 12, 2003 | 07:17 PM
weaklink's Avatar
Resident Retard
I notice that my avcr comes with a boost sensor. What bar is my map sensor and will it enable me to run more than the 1.2 kg/cm2 recognized by the stock sensor?
Old Sep 12, 2003 | 11:04 PM
weaklink's Avatar
Resident Retard
Old Sep 12, 2003 | 11:12 PM
Mahjik's Avatar
Mr. Links
Not sure what the rating is the one that you have, but there is a GM 3 Bar sensor that most people end up using to go higher than the stock 2 bar sensor.
Old Sep 12, 2003 | 11:16 PM
weaklink's Avatar
Resident Retard
I am talking about the one that comes standard with the AVC-R
Old Sep 13, 2003 | 02:27 AM
maxcooper's Avatar
WWFSMD
For your own reference, my stock MAP sensor tops out at 1.15 kg/cm^2.
Note that the AVC-R sensor won't replace the stock sensor in a normal installation. The AVC-R will use its sensor and the ECU will use a different one.
If you have the PowerFC, you might be able to adapt the sensor from the AVC-R for use by the PowerFC, but it is almost certainly cheaper to use the GM 3-bar sensor, and there are settings available on the internet to make it work. But you will need to adjust the ranges and settings with the Datalogit.
What is it, exactly, that you are thinking of dong?
-Max
Old Sep 13, 2003 | 03:37 PM
weaklink's Avatar
Resident Retard
I want to run 20psi. I already have the avc-r, PFC, and datalogit. I have read that the stock sensor reads to 1.2kg/cm2. I wanted to avoid using outside (GM) products, wire splicing etc. I was looking at getting an apex 3 bar sensor when I realized that I had an apex sensor that came with my avc-r. I see now, though that the electronics are different.
Old Sep 14, 2003 | 01:41 AM
duboisr's Avatar
Pm Rotorbrain he has that setup and he will know . To wire in the gm 3 bar with a weather pack connector is a 5 -10 minute job The weather pack connector cost $4 instead of $28 that the dealer wants . I know you do not want that map sensor but someone will want that tidbit .I think the sensor you have is a 3 bar but I would not bet to much money on it ,I am not positive .
Old Sep 14, 2003 | 02:36 AM
weaklink's Avatar
Resident Retard
thanks, I will check into it.
mulcryant
Sep 9, 2015 05:24 PM
befarrer
Sep 4, 2015 08:26 PM
