12A Front cover Warning(13bt swap)
Old Sep 7, 2003 | 10:21 PM
CheddaKing's Avatar
This isn't a question, so relax. I just thought everyone who is planning on using a 12A front cover for their 13BT swap should know... the 13B water pump must be ground down. It physically wont fit until you take it to a bench grinder and make it fit. I suppose you could use the 12A pump(you'll have to check on that) but mine was shot to ****, so i just decided to take the bench grinder and the dremmel to the 13b one. It wasn't that big of a deal, I was just caught off guard by it. It hadnt turned up in any of the research I had done on the swap.
So this goes out to all non -SE swap debaters, there is an extra step out there, so have a bench grinder and a dremmel handy and dont get caught off guard like I did!
Hmmm, I guess I lied, I do have a question, has anyone else that has done this swap had this problem? If so, did u take care of it the same way I did?
Old Sep 7, 2003 | 10:49 PM
Jeff20B's Avatar
Lapping = Fapping
I recently put a 12A front cover on a 20B for an NA swap into an older car. I'm also using a 13B waterpump and will most likely have some time to fit it tomorrow. So far from test fitting it, I have not seen any reason to need to grind anything on it.
Wait, were you talking about the waterpump itself? Or the whole thing with aluminum housing and all? My whole thing is from an '87 6 port engine (NA). I could have used a TII unit, but I think the difference is small enough to ignore; especially on an NA setup.
Old Sep 7, 2003 | 11:09 PM
hornbm's Avatar
FD > FB > FC
Yeah I ran into the same problem. I have the 89 water pump and housing, and a 12a front cover. I ended up having to gring some off of the water pump housing and a little off of the front cover. Works like a charm though!
Old Sep 8, 2003 | 12:25 AM
Jeff20B's Avatar
Lapping = Fapping
I'll look at clearances between the two very carefully tomorrow. Thanks for the heads up!
Old Sep 8, 2003 | 01:49 PM
CheddaKing's Avatar
Jeff-
Yea, the housing, not the actual water pump, i should have cleared that up.
Old Sep 8, 2003 | 03:45 PM
hornbm's Avatar
FD > FB > FC
Mainly its because of the extra bolt the 13b water pump has. And believe me you have to grind off BOTH the front cover and the water pump housing.
Old Sep 8, 2003 | 03:58 PM
CheddaKing's Avatar
I got mine to fit just fine just grinding the water pump...
Old Sep 8, 2003 | 04:05 PM
Metallic_rock's Avatar
Ride 'n Style
well, that answers a few questions... I figured the 12a front cover would work. BTW- I put a 12a water pump on my 13b. works just fine.
Old Sep 8, 2003 | 04:13 PM
CheddaKing's Avatar
I just think it is kind of weird that this has never been mentioned before, it would have been nice to know about it before i put gasket sealent on...
Old Sep 8, 2003 | 04:21 PM
j9fd3s's Avatar
Community Builder
the s5 water pump needs the s5 front cover, ive run into this too
mike
Old Sep 9, 2003 | 12:51 AM
RotaryRevn's Avatar
If you use the front cover from an 85 13b from a gslse do you still need to grind it? Does anyone have any pics of what needs to be grinded?
thanks
Old Sep 9, 2003 | 05:19 AM
frode's Avatar
I am using 12a frontcover on S5 engine with S5 waterpump housing. I had to grind a little on the housing.
Old Sep 9, 2003 | 10:14 AM
rotarygod's Avatar
Rotors still spinning
Anytime I have ever swapped front covers to a different series engine, the waterpump has always had to accompany it. Damn you Mazda! Use the same shapes!
Old Sep 9, 2003 | 02:47 PM
CheddaKing's Avatar
Seriouslly, they want to make it as hard as posisble for us, just to **** us off
Old Sep 9, 2003 | 07:23 PM
hornbm's Avatar
FD > FB > FC
S5's wouldnt be such a pain in the *** if the damn electric OMP didnt stick out so far that the lower pipe on the water pump housing had to be bent differently.
Old Sep 9, 2003 | 08:53 PM
CheddaKing's Avatar
Premix is a beautiful thing!
Old Sep 10, 2003 | 12:58 PM
fatboy7's Avatar
Got Boost?
12A front cover is the same essentially as the -SE 13B cover. On a S5 engine you will have to grind one or both to get it to fit. Check out the big 13BT swap sticky, it was discussed not too long ago.
Old Sep 10, 2003 | 03:12 PM
CheddaKing's Avatar
Yea, i saw that after i posted this, doh! better luck next time i guess
Old Sep 11, 2003 | 01:30 AM
Jeff20B's Avatar
Lapping = Fapping
My S4 waterpump went on just fine.
Old Sep 11, 2003 | 05:47 PM
hornbm's Avatar
FD > FB > FC
Yeah but you cant get rid of the OMP on a S5 unless you get an aftermarket ECU. If you do the stock ecu throws the car into "limp mode" I put some premix in there anyway, just to be on the safe side.
Old Sep 11, 2003 | 08:51 PM
CheddaKing's Avatar
Correction, Premix & Microtech are beautiful things!
Old Sep 11, 2003 | 10:54 PM
Turbo FB.'s Avatar
I have an S4T & 12a cover no problems here.
Old Sep 12, 2003 | 01:50 PM
CheddaKing's Avatar
Yep, its been narrowed down to only the s5 pump gives you a problem, especially if you dont remove the omp
Old Sep 14, 2003 | 01:12 AM
Jeff20B's Avatar
Lapping = Fapping
Here's a pic of a test-fitting of the S4 pump with an S3 front cover.
Old Sep 14, 2003 | 02:41 AM
riffraff's Avatar
smog nazi destroyer
hey, that is not fair.. why did you get an extra rotor with yours.. i want one
