Help:Autometer doesn't fit in RE Amem Steering col pod
Old Sep 19, 2001 | 12:11 AM
technonovice's Avatar
Jinx
Anyone else have these?
1. The Autometer boost gauge cant slide all the way back because the bulb socket and mounting bolts strike the rear of the steerong column pod.
2. I can't secure it because there is not enough room between the side of the pod and mounting bolts to gut the nuts onto the mounting bolts. So it would be loose.
Anyone dealt with this before? Am I going to have to carve this $200 pod up?
These are sold together at Rotary Performance, but I had no idea the fit was so difficult.
Old Sep 19, 2001 | 07:01 AM
misdbman's Avatar
I have the Pettit Steering console pod with an Autometer boost gauge. Perfect fit and cheaper than your RP one. Send it back and get the Pettit.
Old Sep 19, 2001 | 11:15 AM
EugeneChoe's Avatar
the thing i hate about pettit is it doesnt snap in place. i still havent glued it because i dont wanna glue it. im trying to think of a way to glue something to the inside so it will just snap into place. otherwise it cool and cheaper too
Old Sep 19, 2001 | 06:34 PM
misdbman's Avatar
Use black RTV sealant to glue it. This way you can get it apart if you want. Let it set with a bunch of rubber bands around the steering column. It has held fast for over 1 yr including hard autocross cornering.
Old Sep 19, 2001 | 07:39 PM
Jinx
Won't go back any further.
Areas where it hits: Bolts and bulb connector.
Old Sep 20, 2001 | 01:32 AM
Trout's Avatar
I have this set-up but was forwarned by Ari that it required modification. First you need to enlarge the existing holes (the ones you marked) for the Autometer to slide back. Then the mounting studs on the gauge need to be trimed and clean up the threads so that the nuts will go on (it's a tight fit). I used a round metal file to enlarge the holes while carefully holding the gauge pod in the palm of my hand being very careful to distribute the load over a large area. Since this gauge holder is made for RH drive the washer and blinker stalks are reversed (you'll see what I mean) so if you want a clean fit the sides should be trimed to match the bottm half of the steering console but it's not necessary.
Only the RE gauge will fit this holder perfectly.
In regards to the Petit column mount and its cheaper price. The RE pod more closely resembles a factory piece in construction, appearance and real mounting tabs. It depends how tight your budget is but a basic boost gauge and pillar mount can be had much cheaper than either Petit's $189 or RP's $250 set ups - both overpriced for what you get. Jack
Old Sep 20, 2001 | 02:59 PM
rtryrktrx7's Avatar
I was told before hand also. I took a drimel tool and made the holes bigger. THen I pushed the gauge as far as I could. I got some needle nose and pried the two bolts inward to get the gauge in as far as I could then I just let the bolts go. The pressure of th etight fit was enough to hold the gauge in. Here's how mine turned out.
Old Sep 20, 2001 | 03:00 PM
rtryrktrx7's Avatar
Here's another
Old Sep 20, 2001 | 03:01 PM
rtryrktrx7's Avatar
And yet another
Old Sep 20, 2001 | 04:32 PM
Jinx
Those results look encouraging.
How did you handle the bulb socket?
Old Sep 21, 2001 | 10:40 AM
rtryrktrx7's Avatar
Just made the opening bigger. Enough to get it to slide through. It was a very tight fit. Took some patience, not to break the plastic. But it definitely paid off. I think it looks awesome. Are you going to paint the rim of the chrome as well. It made such a difference with mine.
Snoopy FD
Dec 8, 2015 01:45 PM
ncds_fc
Sep 10, 2015 03:52 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
