driver side fubar
Old Jul 31, 2003 | 09:52 PM
driver side fubar
I have a 93 base rx7 and my door handle from the outside has been getting really bad
i really have to yank at it to get it to open...
i dont' have any experience taking doors apart so if anyone has had a similiar problem send me a pm and tell me how or where to fix it
thanks guys
Old Jul 31, 2003 | 10:39 PM
skunks's Avatar
I'm a CF and poop smith
holy crap, stop yanking it! just open it and take off the door cover from the inside and spray it with wd-40 (a lot all over inside thru the holes in the door) that should loosen things up a lot
Old Jul 31, 2003 | 10:44 PM
Mahjik's Avatar
Mr. Links
Yep, just order a new one (around $130):
Malloy Mazda
1-888-533-3400
Talk to Ray Crowe
It's pretty easy to replace. Just pull the plastic piece covering the back of it from inside the door. Then, there are 2 bolts exposed (10mm I think). Remove those and the outside handle will be lose.
Pop the little plastic holders off the rods and then you can get access to removing the actual lock. Place the lock into the new handle, mount and attact the rods and you are pretty much done.
Old Aug 1, 2003 | 12:01 AM
thanks i think ill order a new one
the old one 's door lock was also fubar
also has anyone ever experienced a squeek coming from the inside of the mirrors...kinda near da door panel
i hear it from both sides and it bugs the crap out of me
any ideas? on this one
Old Aug 1, 2003 | 04:22 AM
BoostedRex's Avatar
NorCal 7's Co-founder
I have a '93 Touring that I'm parting out and still have both door handles that work perfectly if you would like to save yourself some money and buy them off of my car. If you're interested PM BanzaiToyota as he is in charge of parting my baby out while I'm overseas. Hope that helps some. Laterz.
Zach
Old Aug 1, 2003 | 06:57 AM
dgeesaman's Avatar
BEFORE you buy a new one (or while you're waiting for the new one to arrive) you need to try some white lithium in the spray can. Shoot it into that sticky lock where the key goes in, and shoot everything on the back. Don't use WD-40 - it will work, but it won't last.
Lithium grease = $5 and easy to find.
Dave
Old Aug 1, 2003 | 09:10 AM
BoostedRex's Avatar
White lithium grease is what he's talking about and he's right. It also works great on sunroof tracks when they start to stick. Good call Dave.
Old Aug 1, 2003 | 09:35 AM
Mahjik's Avatar
Mr. Links
Yes, but it's only a temporary fix. The handle will break eventually (just ask me how I know). May as well fix it right the first time which is what I should have done.
Old Aug 1, 2003 | 09:38 AM
dgeesaman's Avatar
My understanding was that an unlubricated handle mechanism sees lots more friction. Symptom = hard to close/open. Result: much greater stresses and broken parts.
Are there some wearing components in this assy I'm not aware of? Or parts that fail eventually no matter what?
Dave
Old Aug 1, 2003 | 09:41 AM
Mahjik's Avatar
Mr. Links
Mine just completely broke. After two applications of grease, one day it just snapped (lasted about 3 months). It sucked having to open the driver's side door from the passenger side.
If he's already yanked hard on it a few times, chances are some damage has already been done.
Old Aug 1, 2003 | 09:44 AM
BoostedRex's Avatar
And those handles are FAR from a strong part when it comes to abuse. I have been through a set on my old FD as well. The ones that I'm parting out aren't that old and I know they both work GREAT!!
Old Aug 1, 2003 | 01:02 PM
hmm how much you charging for your driver side door handle/lock combo thingy??
also anyone have any ideas on why my door panel near the mirror squeeks...???? both sides
Old Aug 1, 2003 | 01:33 PM
BoostedRex's Avatar
Any and all parts prices or info needs to be routed through BanzaiToyota. He's in charge of parting out my baby while I'm overseas for the next 15 months. Just PM him and he'll sort you out. Laterz.
Zach
