Reading Error Codes
Old Sep 16, 2001 | 01:14 AM
AdamP's Avatar
Reading Error Codes
Is there any way that I can get the error codes out of my car with out taking it to mazda?
AdamP
Old Sep 16, 2001 | 01:35 AM
jr's Avatar
jr
Jump the TEN and GND pins inside the little black Diagnostics box. The box is under the hood on the drivers side, it says Diagnostics right on it. Once you do that turn the key on and watch the Check Engine light, it'll blink out the codes. Here's a list with instructions that I took from a website:
ECU Error Codes
To cause the ECU to flash the error codes on the MIL, short the TEN and GND terminals on your diagnosis connector, with the ignition off. Then turn your key to the "on" position and count the flashes.
To clear the error codes, disconnect the negative battery cable for at least 20 seconds, and depress the brake pedal. Re-connect the battery cable.
In the "pattern" column, the "L" stands for a long flash, and the "S" stands for a short flash.
Code Pattern Problem Memorized
02 SS Crank angle sensor no NE signal Yes
03 SSS Crank angle sensor no G signal Yes
05 SSSSS Knock sensor open or short circuit Yes
06 SSSSSS Speedometer sensor Yes
09 SSSSSSSSS Water Thermosensor open or short circuit Yes
11 L S Intake Air Thermosensoropen or short circuit Yes
12 L SS Full Range Throttle sensor open or short circuit Yes
13 L SSS Pressure Sensor open or short circuit Yes
14 L SSSS Atmospheric pressure sensor (in ECU)open or short circuit Yes
15 L SSSSS Oxygen Sensor less than .55v for more than 120 sec in feedback mode Yes
16 L SSSSSS EGR Switch open or short circuit Yes
17 L SSSSSSS Feedback System No change for 25 sec in feedback mode Yes
18 L SSSSSSSS Narrow Range Throttle Sensor open or short circuit Yes
20 LL Metering Oil Pump Position Sensor open or short circuit Yes
23 LL SSS Fuel Thermosensor open or short circuit Yes
25 LL SSSSS Pressure Regulator Control Solenoid open or short circuit No
26 LL SSSSSS Metering Oil Pump Stepping Motor
27 LL SSSSSSS Metering Oil Pump Sensor open or short circuit or MOP sticking Yes
28 LL SSSSSSSS EGR Solenoid open or short circuit No
30 LLL Split Air Bypass Solenoid open or short circuit No
31 LLL S Releif 1 Solenoid open or short circuit No
32 LLL SS Switching Solenoid open or short circuit No
33 LLL SSS Port Air Bypass Solenoid open or short circuit No
34 LLL SSSS Idle Speed Control Solenoid open or short circuit No
37 LLL SSSSSSS Metering Oil Pump low battery voltage Yes
38 LLL SSSSSSSS Accelerated Warmup System Solenoid open or short circuit No
39 LLL SSSSSSSSS Releif 2 Solenoid open or short circuit No
40 LLLL Purge control Solenoid open or short circuit No
42 LLLL SS Turbo Precontrol Solenoid open or short circuit No
43 LLLL SSS Wastegate control Solenoid open or short circuit No
44 LLLL SSSS Turbo control Solenoid open or short circuit No
45 LLLL SSSSS Charge control Solenoid open or short circuit No
46 LLLL SSSSSS Charge Releif Solenoid open or short circuit No
50 LLLLL Double Throttle control Solenoid open or short circuit No
51 LLLLL S Fuel Pump Relay open or short circuit No
54 LLLLL SSSS Air Pump Relay open or short circuit No
71 LLLLLLL S Front Secondary Injector open circuit No
73 LLLLLLL SSS Rear Secondary Injector open circuit No
76 LLLLLLL SSSSSS Auto Tranny Lockup Signal open or short circuit No
77 LLLLLLL SSSSSSS Auto Tranny Reduce Torque Signal
If more than one failure is present, the codes will be indicated in numerical order, lowest number first.
Old Sep 21, 2001 | 12:36 PM
Talking Found it
Every third gen owner needs a print out of this.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZacMan
Sep 19, 2015 09:20 PM
yetter227
20
Sep 5, 2015 11:57 PM
