What's the exact weight of the shortblock?
Old Jul 9, 2003 | 02:58 PM
ZachSpazz's Avatar
I wish I had a posse...
How much does a shortblock 89-91 TII engine weigh, without the oil-pan, water-pump, etc. The oil-pump is still on the block, as is the front cover. I need to get my engine shipped off, and FedEx will ship it, as long as it weighs 150 lbs or less. If the weight is over the limit, then I guess I'll have to have it trucked.
Yes, I did try to search.
Old Jul 9, 2003 | 03:00 PM
Rxmfn7's Avatar
Do a barrel roll!
Im not 100% positive, but I think it will be somewhere closer to 250lbs... Can anyone else confirm this?
Old Jul 9, 2003 | 03:07 PM
ZachSpazz's Avatar
i recently had a 13b shipped to me,,and its weight was 225lbs
this was a bare block to,,no mainolds no oil pan omp or anything
so i believe a fully equipt turbo engine would weigh in the 300 range and a fully equipt N/A would be close to 260
I just found this after doing a search with different keywords.
Damn. It looks like I'll have to deal with the hassle of getting the engine trucked.
Old Jul 9, 2003 | 04:55 PM
dr0x's Avatar
pei > caek
Estimated 230lbs.
When I shipped my motor it weighed in at 249lbs. My big *** wood crate I made for it I am guessing to be about 20lbs. Truck shipping is cheaper than fedex would be for it anyways.
Old Jul 9, 2003 | 05:06 PM
bill Shurvinton's Avatar
I weighed a 13B short block and got just over 190lbs
Old Jul 9, 2003 | 09:46 PM
Turbo Driver
Yeah, it's definately over 150lbs....
One of my non rotary friendly friends said one day when discussing pulling my engine "what does that weigh, 50lbs?" I just laughed. I found out first hand othewise...heave little bitches.
Old Jul 9, 2003 | 11:40 PM
Icemark's Avatar
it can't be too much over 200 lbs, as I can lift one out of the back of my truck by myself.
I have one partial stripped that I will try and weight in the morning
Old Jul 10, 2003 | 12:09 AM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
I can't see them weighing over 200 AT ALL.
but maybe.. I am 6'0 150LB and am NOT very muscular and managed to put a 13b-t shortblock into the back seat of a cavalier alone. it was not easy, but hey, it was done.
there's no way in hell that it's only 150LB though.. and if it is, its gotta be damn close t being more than that.
Old Jul 10, 2003 | 12:44 AM
drago86's Avatar
Its gotta be less than 200 dry, lets add it up,side plates 3 @ ~30 lb each=90 lb, rotors 2 @ ~10 lb each=110 eshaft 1 @ ~15 lb's =125, housings 2@ ~ 10 lbs each = 145 front cover/oil pump/ crap up front probably ~20 lbs thats 165 flywheel ~25lb (or less if aftermarket) =175-190 lbs,.. hmm i guess im stronger then i thought, these are all approx weights from memory, id love to see soemone do it with the real weights ( side plates a a lil less than 30 lbs, like 27 front and rear, and like 22 center, and rotors are a lil more etc)
Old Jul 10, 2003 | 01:18 AM
neevosh's Avatar
The Dude Abides
Shortblocks with the water pump and oil pan weigh about 200-210 lbs. I've had a few engines shipped and that's what they weighed.
Old Jul 10, 2003 | 01:55 AM
ERAUMAZDA's Avatar
thoses scales always add a couple punds
Old Jul 10, 2003 | 02:46 AM
hypntyz7's Avatar
I ship engines almost daily. A shotblock will weigh in at 185-190 lb dependig on year and model (the irons and rotors varied in weight slightly). Add 20-30 lb for pallet weight to that. This is most definitely not a UPS item.
I usually get blocks shipped in the eastern US for $75-100. check out www.gorlc.com for a rate quote...you need to know that an engine is class 85 for the quote. Residential delivery extra.
Old Jul 10, 2003 | 09:56 PM
silverrotor's Avatar
Not to divert from the thread, but how much would an s5 TII Motor, with Manifolds, Turbo etc weigh at?
I'll be transporting mine this weekend and would like to anticipate It's weight.
Old Jul 10, 2003 | 09:58 PM
hypntyz7's Avatar
A long block generally weighs around 375 or so.
Old Jul 10, 2003 | 10:08 PM
Thanks for the reply. The Longblock doesn't Include the Transmission does It? I won't be picking It up this weekend. Is It still 375lbs. or so?
Old Jul 10, 2003 | 10:25 PM
Mr. Gadget's Avatar
Older than Dirt
And be careful if it is a residential, carriers can and will hit you with a liftgate charge at times. Basically anything over 75-100 lbs thats not a dock is open based on tariff to liftgate charges. Some good carriers will wave, just beware.
Old Jul 10, 2003 | 11:01 PM
hypntyz7's Avatar
I consider a longblock everything including wiring, back to the flywheel. No transmission.
R & L is very good about this...even if it is a business without a dock, they charge no liftgate fees in most cases...only for strictly residential deliveries. I have all my customers either do dock pickups or set a delivery to business. I either do dock dropoff, or meet the driver while he is in town and slide the smaller loads into his trailer at one of his daily stops.
MILOS7
May 9, 2016 06:39 AM
