Good advice for prospective FD owners
Old Jun 24, 2003 | 11:46 AM
Thumbs up Good advice for prospective FD owners
Well, at least I consider it good advice . I just PMed this to a curious potential buyer, and thought I'd toss it out there for others new to the ways of the FD.
My intent was to give advice on the "minimal mods" to make a bone stock 3rd Gen relatively reliable and streetworthy.
Here it is, short and sweet.
Boost Gauge ~$100
Water Temp Gauge (stock one is junk) ~$150
Turbo Timer ~$100
downpipe (exhaust component between turbos and main cat). Replaces the pre cat, which can clog and hurt your engine. ~$250.
Aluminum AST (coolant burp tank, replaces stock plastic tank which can burst and lead to overheating) ~$150.
Silicone hoses to control operation of the Sequential Twin Turbos (stock are rubber and crack/break/pop off, leading to boost problems). ~$100.
It's also a good idea to replace the stock radiator with an all aluminum one (stock plastic end tanks can crack) ~$500.
That's about all I can think of as a minimum. $1350 in parts, with labor not included. Basically, don't overheat (~240 deg F) the car, and don't overboost it (~10 psi). Change the oil every 1500-2k miles. Use 93 octane religiously. Warm her up, cool her down. Drive and enjoy .
Old Jun 24, 2003 | 11:48 AM
scratchjunkie's Avatar
sexy no jutsu
amen
Old Jun 24, 2003 | 11:55 AM
spurvo's Avatar
don't race, don't need to
The only thing I'd throw in there would be a fan mod, or Miata thermoswitch.
Fan Mod for president.
Old Jun 24, 2003 | 01:29 PM
HeatTreated's Avatar
Hi Powr FD's
agreed. Fan Mod is so cheap and great, especialy for this summer heat.
also, you can save money and linearize the Water Temp gauge
Old Jun 24, 2003 | 01:46 PM
Forgot about the Fan Mod. I've had the damn thing for so long I thought it came stock
As far as linearizing the temp gauge, it's definitely an option. Kan has it done on his CYM and I don't like it. My Greddy 60mm with Peak/Hold and Warning flasher seems a better choice to me.
Good input guys, keep it coming .
Rich
Old Jun 24, 2003 | 02:19 PM
CrispyRX7's Avatar
Polishing Fiend
How about:
Synthetics in the diff and tranny. $30
5th gear selector spring upgrade ($15? OE part) to lessen the chance of that oh so costly missed 2-3 upshift and subsequent synchro destruction.
Turbo coolant hoses $40
I'd nix the turbo timer as non essential but nice to have. With proper cool down driving I don't think it's needed. Some may argue but that's just my opinion.
Temp gauges can be had for less than $150. You "top of the line" guys maybe need that $150 gauge but a $40 digital gauge is equally as effective...just not as pretty.
My 2 cents,
Crispy
Old Jun 24, 2003 | 03:05 PM
mks's Avatar
mks
More info on this please. Internal tranny part? How hard to replace? Ok, ok, I'll go search..
Old Jun 24, 2003 | 03:27 PM
CrispyRX7's Avatar
Polishing Fiend
I've not done this myself <ulp> but I understand it to be a stiffer shift select spring. This is a new Mazda part. They no longer sell the "old" weak spring. If you do a tranny rebuild or have the tranny out for a clutch job from what I undertand it's a 15 minute swap. Some even say it can be done with the tranny in the car. Is all I know. But it certainly might save a new owner a tranny rebuild before they ham fist a shift while still getting accustomed to their new car.
Regards,
Crispy
fastrx7man
33
Sep 2, 2015 09:42 PM
