Replace stock radio/EQ with after marker receiver?
Old Jun 17, 2003 | 10:47 AM
ACRx7-85's Avatar
Question Replace stock radio/EQ with after marker receiver?
I want to replace the stock radio/EQ with an after market radio/CD receiver. I called Cruthcfield and they said they have several receivers that will fit BUT some tabs need to be cut for the receiver to fit. They also said they has a faceplate that will fit. Has anyone done this and is it a major modification. I don't want to screw up the outer plate. How does the after marker receiver look after installation? Is Cruthchfield BS me or is this going to work?
Old Jun 17, 2003 | 11:36 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yeah it will work, a lot of people have put aftermarkets in. 84-85 nothing has to be cut, just a kit installed.
79-83 will have to have some metal corners filed. And the dash panel will have to be cut to accept a DIN radio (7in x 2in)
I personally perfer mounting the radio in an ISO DIN. That way the radio is actually mounted behind the face panel, and is then flush with the dash for a more factory look, but this takes a lot more patience to get it to look perfect.
Also wiring on these arent straight forward, this is probally a 7 out of 10 diferculty level to do. The ISO DIN being maybe an 8.
Old Jun 17, 2003 | 03:45 PM
vipernicus42's Avatar
Rotoholic Moderookie
Does anyone have a wiring diagram for it?
Jon
Old Jun 20, 2003 | 05:31 PM
Jon017's Avatar
There is a pic of the stock wire diagram. I think when i was lookin at it it looked backwards though. For a wire diagram for ur aftermarket deck they ussually come with those.
Jon017's Avatar
Jon017's Avatar
sYnth.
Aug 19, 2015 06:27 PM
tsmith94FD
Aug 16, 2015 05:41 PM
