motor coming out what to do
Old May 20, 2003 | 03:24 PM
T88Rx7's Avatar
No No not for a rebuild just for inspection and some modifications, getting the power FC and Datalogic put in along with some other things, so i want to inspect the motor and turbos B4 doing the setup, im staying stock for now, what should i do B4 putting it back in
Old May 20, 2003 | 03:27 PM
93BlackFD's Avatar
built my own engine
umm, reevaluate your decision....i'd do major work when having the engine out (after having pulled mine this weekend)
i am going full non seq, street ported motor, etc
Old May 20, 2003 | 04:13 PM
SlyderZero00's Avatar
Yeah mine is out right now too...if you need a clutch, flywheel, radiator, etc..do it now. Save ya time and money in the long run.
Old May 20, 2003 | 04:36 PM
T88Rx7's Avatar
already got the clutch put in by Rx794, now im just gunna take out all the emissions and block them, and go FULL non sequential...
Old May 20, 2003 | 04:54 PM
paw140's Avatar
So you are going to pull the engine, take it apart and look at it, not rebuild it, and put it back together? Sounds like a waste of time to me. Why don't you just do a compression test and be done with it?
Old May 20, 2003 | 05:06 PM
Mahjik's Avatar
Mr. Links
I agree...
However, if you are going through the trouble you may as well:
1. Have your injectors cleaned and flow balanced
2. Replace coolant lines
3. Clean the engine bay
4. Have any parts polished that you want polished
5. Good time for the vacuum hose job if it hasn't been done
Old May 20, 2003 | 05:53 PM
T88Rx7's Avatar
no im not opening the motor!!!! im pulling the motor for a cleaning in the engine bay and doing the secondary injectors (which i know doesnt require to pull the motor) im plus i need to change the wire harness too so ima just do everything at once besides the expensive part...lol... ill wait till she dies on me then rebuild.
Old May 21, 2003 | 06:57 AM
paw140's Avatar
It's totally your choice, but you can clean up the engine bay pretty well with the engine still in there. You ever see how clean used-car dealerships get the engine bays? It seems like the reasons you are giving for pulling the engine can all be done with the engine still in place. Pulling it out is not a small job.
Old May 21, 2003 | 11:08 AM
apneablue's Avatar
Wow, hats off to you dude...I thought I was **** but you take the cake...Gonna pull the engin and clean the bay huh? Wow! I think you should just save yourself some time and pull it when it needs a rebuild...you can replace your injectors and clean the bay really well without having to pull it...
Old May 21, 2003 | 04:06 PM
T88Rx7's Avatar
no its not only that every hole that is left open from removing all the emissions are gunna be welded because block off plates dont seal good enough.
cristoDathird
28
May 30, 2019 08:47 PM
incubuseva
14
Sep 3, 2015 12:37 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
