a/c problem?
Old May 9, 2003 | 01:33 AM
m007lee's Avatar
Unhappy a/c problem?
Hi,
Hope somebody can help me with this. When I accelarate w/ my air conditioning on, the engine seems to hestitate and make the car jerk. When I turn off the air conditioning, the engine slowly returns to normal operation. Does it have something to do with the electrical or .....? I really need to get this fixed since it is getting really hot at where I live. Your help is greatly approciated. Thanks!
Mike
Old May 9, 2003 | 01:46 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
the a/c compressor is kicking on and off... basically just don't do that... or option 2 you have to much or little freon in the system causing one of the pressure valves to trip the compressor... what are your mods...?
Old May 9, 2003 | 02:09 AM
m007lee's Avatar
My car is totally stock and is AT. Thanks.
Mike
Old May 9, 2003 | 11:59 AM
maxpesce's Avatar
Ex fd *****
The ECU should disingage thw AC compressor clutch breifly when it senses Throttle tip-in at low - med speed (change in throttle position to more open) the Throttle position sensor may be faulty or misaligned - or the AC Clutch may be sticky and not releasing.
Old May 9, 2003 | 02:27 PM
rx7racer11's Avatar
whenever i had my air on in my auto it would do the same thing mine was actually dying unless i would foot brake it and keep Rpm's up At stop lights etc... it sucked
Old May 11, 2003 | 11:44 PM
m007lee's Avatar
so did u find out what happened? Thanks.
Mike
Old May 12, 2003 | 10:52 AM
maxpesce's Avatar
Ex fd *****
Thats exactly what mine was doing also - I developed the habit of hitting the AC button to turn off the ac as I aproached a stoplight - a habit that took about 3 months to break after I had my engine rebuilt.
My stalling problem was caused by LOW COMPRESSION - and yes the symptoms are agrevated by the Auto Trans.
Old May 12, 2003 | 02:49 PM
rx7racer11's Avatar
Mike
nah i blew my engine.. kinda took my mind off the a/c prob
rotor_veux
Sep 19, 2015 07:13 PM
