Slight fuel problem, wont start
Old Mar 16, 2003 | 07:12 AM
V8kilr's Avatar
well I just picked up another 2nd gen and if you leave it sit for a while it will turn over and fire up,
but it dies shortly after.
then if you turn it over again it wont start, I am pretty sure its dumping to much fuel
the car has new spark plugs, plug wires,and I changed the crank trigger dizzy
still no luck
I am thinking of swapping out the o2 sensor and checking the coil packs
I know there are several adjustments for the fuel, should I play with these?
what is the most common thing in a situation like this?
I assume the engine still has good compression, or good enough, its an automatic and it will brake torque. thats more then my last one did and it ran just fine.
the rex is a 89 GTU
any help is greatly apriciated
thanks
Old Mar 16, 2003 | 07:18 AM
HeffBoost's Avatar
Keep Right Except to Pass
It sounds like you need to get the idle up or fix the out-of-wack component causing it to not fast-idle. This is on cold startup correct? I would assume flooding as the reason it won't restart.
Old Mar 16, 2003 | 07:22 AM
V8kilr's Avatar
Idle sits normal when it does idle, I had it running for a while when I took the time to play with it, but if I have to spend 3 hrs every day to get it to start then its kinda not practical.
its just the initial startup, what about the idle control on the throttle body and the air/fuel ratio
also I remeber there was another adjustment down by the airbox on my 87 but not on this 89
I am somewhat lost on 2nd gens
Old Mar 16, 2003 | 07:32 AM
HeffBoost's Avatar
Are you getting a check engine light? The screw on the top of the TB is the main idle adj.. The R/L pot on the shock tower is for idle mixture. The one on the airbox(edit - S4, I'm not sure about the s5 afm) is a bypass and I wouldn't touch that one if I were you.
Old Mar 16, 2003 | 10:19 AM
V8kilr's Avatar
the shock tower was the one I was referring to , not the air box, sorry.
but its not there on my 89?
maybe its just not in the same spot.
I will try the tb adjustment but with out the little dual leds its kinda a shot in the dark, plus i could be playing with something thats not even the problem.
any more ideas?
thanks
Old Mar 16, 2003 | 10:56 AM
Aaron Cake's Avatar
Engine, Not Motor
Do NOT adjust anything. There is another problem, and those adjustments don't spontainously go out of wack. However, if the previous owner screwed with it...
Have you done a compression test? Are you running rich (black, greasy plugs, black smoke, fuel smell)? Intake leaks? They would cause the car to start up and run fine (car runs rich on cold start) but after it warmed up and leans out it would die...BAC valve good?
If the car has been sitting, stuck or badly leaking injectors are a good possibility.
But don't go any further until you verify compression.
Old Mar 16, 2003 | 01:36 PM
V8kilr's Avatar
I'm pretty sure the compression is fine, I havent really played with the adjustment screws,
I turned them a couple turns one way and back the other, then put them back where they were.
there isnt any black smoke that I see.
I do smell heavy fuel
I removed the plugs several times and they are pretty clean.
the o2 sensor also looks new.
what is the bac?
Old Mar 16, 2003 | 02:55 PM
Aaron Cake's Avatar
Engine, Not Motor
Search for info on the BAC (bypass air control valve). You can't "assume" compression is good. Test it properly so you don't spin your wheels on an engine that could be damaged internally.
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
