which fuse
Old Feb 2, 2003 | 02:23 PM
SUPRAMAN
which fuse
what fuse controls the brake lights on an s4 tii. I looked on the panel but nothing says brake or lights. Anyone know?
Old Feb 2, 2003 | 02:29 PM
600HP CLUB's Avatar
15A? i know it's called illumination.
Old Feb 2, 2003 | 02:33 PM
600HP CLUB's Avatar
do u mean brake light as WHEN U BRAKE?
does ur interior dash light work?
-mike
Old Feb 2, 2003 | 03:10 PM
SUPRAMAN
yeah the lights come on but when you puch the brake pedal they don't get brighter. The horn doesn't work either someone told me they were the same fuse.
Old Feb 2, 2003 | 03:40 PM
HAILERS's Avatar
HAILERS
A series four has a 20 amp fuse called....are you ready?....STOP.
Old Feb 2, 2003 | 03:54 PM
HAILERS's Avatar
HAILERS
Old Feb 2, 2003 | 08:04 PM
SUPRAMAN
so ill pop a new fuse in tomm
Old Feb 3, 2003 | 05:31 PM
SUPRAMAN
well i poped a new fuse in there and it didn't do anything. But there was a red wire running underneath the fuse with the copper touching the fuse i don't know what that goes too.
Old Feb 3, 2003 | 05:42 PM
HAILERS's Avatar
HAILERS
If the fuse is good, then take a look at the stop light switch. Located in front of the brake pedal I think. Take the plug apart and see if 12v is at the green/white wire.
If 12v is on the green/white wire, then reconnect the switch and then go to the CPU near the left foot, and take the plug off. Put a meter on the WHITE/GREEN wire in the plug and step on the pedal. If you don't have 12v on the meter, ohm out the brake switch. If you do have 12v at the CPU plug with the brake pedal depressed.......well that's for another day.
FC3S Timmy
16
Oct 3, 2015 01:08 AM
whinin
Sep 23, 2015 04:09 PM
poop2003
Sep 21, 2015 10:28 PM
