400rwh w/engine & stock turbos(non-seq)
Old Jan 25, 2003 | 05:28 PM
Boostn7's Avatar
For those that said it could not be done .......
Just got off the dyno and here are the results...
402 rwh and 356rwt.....
4x850cc injectors maxed out !! mid-high90% !!!
map sensor....maxed out...1.13-1.14kg/cm2 or 17.5psi
air/fuel ratio.....mid-high 10's 'til 6krpm and 11.0 after that..
Later
Old Jan 25, 2003 | 05:33 PM
Wargasm's Avatar
Weird Cat Man
We want the sheet!
Good job!
Brian
Old Jan 25, 2003 | 05:44 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Holy ****. Yeah post it!
Old Jan 25, 2003 | 05:45 PM
Boostn7's Avatar
Here it is.....
check out the curves
Old Jan 25, 2003 | 05:52 PM
rotaryextreme's Avatar
Veteran: Navy
Great Job. Want to share more info
Can you share more info on what mods you have so we can compare your dynosheet with the sequential? I did one for 386.6 rwhp at the same boos as you. The dynosheet is at the other thread.
Chuck Huang
Old Jan 25, 2003 | 06:08 PM
Boostn7's Avatar
Here it is.....
Old Jan 25, 2003 | 06:19 PM
RX-8's Avatar
Great job! How the hell did you manage that on stock turbos and engine. Please tell us your secrets!
Old Jan 25, 2003 | 06:22 PM
GsrSol's Avatar
Z06 powered FD
Very nice! Your 1/4 mile backs it up too.
Hail to the fast white FD's
Old Jan 25, 2003 | 06:46 PM
Wow...its not even ported motor???
great tuning man~!!
Old Jan 25, 2003 | 06:49 PM
Boostn7's Avatar
here's one more....
Old Jan 25, 2003 | 06:54 PM
Marshall's Avatar
I think it finally, slowly but surely, coming out what a properly running and tuned FD with good turbos can do.
Congrats to you and the 386 rwhp guy also.
Boostn7's Avatar
one more....
Old Jan 25, 2003 | 07:00 PM
Veteran: Navy
How many runs did you pull on the dyno? Like 50 runs? I hope this dynoshop is owned by a friend of yours and doesn't charge much. Still no info at all on your car??
Chuck
Old Jan 25, 2003 | 07:14 PM
kwikrx7's Avatar
I wouldn't run 18 psi on the stock turbos for long. But wow, those are the best numbers I've ever seen for stock motor and turbos - something doesn't seem to add up but you have a dyno sheet to prove it - who is your tuner, or do you tune it yourself? Post your mods
Old Jan 25, 2003 | 07:24 PM
Bucrx7's Avatar
CONGRATS!! You must be one hell of a pfc tuner. If I remember correctly that is what you used. 400 rwhp on stock motor now that's unbelieveable.
Old Jan 25, 2003 | 07:30 PM
Boostn7's Avatar
THANKS GUYS
kwikrx7: take a look a this video
http://www.vosko.net/media/rx7vssupr...supraday-1.wmv
.....and maybe you'll feel differently......I'm suprised myseld but it has alot to do w/ tunning and combination of parts!!!
Never imagine to go this far with a PowerFC !!!!
The ECU is awesome with the dataloggit is even better. (thanks-RX794)
There was afew witnesses there which are on the forum
Sorry no video...
Old Jan 25, 2003 | 07:40 PM
vosko's Avatar
Just Call Me Terminator!
john you shoulda called me i would have taped it for you! i know boostn7. he is a great guy willing to help anyone and one hell of a tuner !!!! i went to the track a few times with him.... he knows his stuff. drives to the track gets kicked off for running too fast without a roll cage! i can't wait to get video of him running 10.99... it will happen!
Old Jan 25, 2003 | 08:19 PM
That's insane.....what do you figure helped you make the extra power?
Old Jan 25, 2003 | 09:06 PM
neoamd's Avatar
LS Powered
and please share all of your mods
Old Jan 25, 2003 | 09:18 PM
RX-8's Avatar
Why bake the pie and not share a slice? Mods please.
Old Jan 25, 2003 | 09:22 PM
Wargasm's Avatar
Weird Cat Man
Hello,
I added you to my dyno page at http://www.catenet.net/dyno.php
Brian
Old Jan 25, 2003 | 10:06 PM
RX794's Avatar
NYC's Loudest FD
Just think about this: Boostn7 still has more to go, he stopped tuning because he ran out of injector duty cycle. If(and I know he will, even though he says he won't, hehehe) he gets bigger injectors the car will make more power cause he'll be able to turn the boost up and do a little fine tuning to those splits like we did today(Hey Boostn7, now do you believe me about the ignition accuracy as far as split is concerned with the PFC?). Also as a side note, imagine this car with more fuel and a ported motor, can you say at least 420RWHP on stock turbos?, not to mention the torque, SICK.
Old Jan 25, 2003 | 10:23 PM
Great job man! Like others have been saying.. please break the mod list out..
Old Jan 25, 2003 | 10:37 PM
ErnieT's Avatar
Living life 9 seconds at a time
The dyno numbers are very impressive. Same boost I ran with my stock twins to run 11.69, but your mph was 3mph more. As for getting more power by running more boost, your simply going to overspin and overheat the turbo's. They just arn't big enough to make effective power. Your intake charge temps will go soo high, even if you tune to a safe a/f ratio, you'll still detonate. I say be happy with what you have till ya go single turbo. Have fun!
And I understand if you don't list mods or anthing else. I know how much work, R&D, and most of all, money that it takes to get these cars to the edge, just to give it all away.
Old Jan 25, 2003 | 10:39 PM
vosko's Avatar
ok you guys don't know about his "other" FD (i've seen it in person) ...... ummm lets just say it will be a weee bit faster than his full street FD
