View Poll Results: Do you add premix to your gas?
Yes.
78
49.37%
No.
59
37.34%
whats premix?
21
13.29%
Voters: 158. You may not vote on this poll
FD guys, do you premix?
Old Jan 7, 2003 | 11:48 PM
jacobcartmill's Avatar
just dont care.
we did a poll like this in the FC section and 67% of fc drivers run premix... alot more than i thought.
Old Jan 8, 2003 | 12:21 AM
GoRacer's Avatar
Speed Mach Go Go Go
I just use 4 seconds of MMO (like how I measure). It's very cheap compaired to two stroke oil. I don't think it smokes as much or at all rather. I'm not as worried about lowering the octane level with it as I am with two stroke. Although I have no idea how much two stroke actually lowers it and if it is even a significant amount to worry about.
Do 2nd Gen's have a oil metering pump? That's a high percentage. I would guess only 1/3 3rd Gen guys pre-mix.
Old Jan 8, 2003 | 12:57 AM
just dont care.
yeah all the 13b's have OMPs.
the S4's (86-88) have mechanical omps and the S5's (89-91) have an electric one.
i'm assuming that the 13brew has an electric one as well?
Old Jan 8, 2003 | 01:42 AM
spurvo's Avatar
don't race, don't need to
4 oz MMO every fill up. Soooo much smoother... 19 inches of vacuum at idle with 64K miles too!
Old Jan 8, 2003 | 02:02 AM
Oh yeah!! Of course, I don't really have a choice considering the single turbo and the bridgeport. All the factory equipment is removed. Premix is the only way to lube up my housings. I still only get 5 inches of vacuum idling at 1800rpm.
Old Jan 8, 2003 | 02:26 AM
spurvo's Avatar
Yeah, and you would blow by my stock machine like I was Chrysler LeBaron. A REEEEAAAALLLYYYY swoopy, pretty one, though...
Old Jan 8, 2003 | 02:35 AM
maxcooper's Avatar
WWFSMD
Keep in mind that people who care to pre-mix are more likely to vote, so don't take the results of this poll as the real proportion of pre-mixers.
-Max
Old Jan 8, 2003 | 05:32 AM
airn's Avatar
what is MMO?
Old Jan 8, 2003 | 08:07 AM
Scrub's Avatar
bow leggin'
Marvel Mystery oil. You can buy it at pep-boys auto zone. Wit works good. You can mix it in with your oil change too if you wanted.
Old Jan 8, 2003 | 10:54 AM
HDP's Avatar
HDP
A Fistfull of Dollars!
Do you mix it with the gas or the oil?
Old Jan 8, 2003 | 01:12 PM
BoOsTin FD's Avatar
Powered by** Rotary
I put 4oz of MMO in the gas tank at every fill up. I didn't know i could use it with the oil change too. Great stuff, cheap too, you can get it at walmart too.
Old Jan 8, 2003 | 02:26 PM
ArchangelX's Avatar
Why would you pre-mix? I didn't see anything about that in the Operator's Manual.
What's the reasoning behind it? Is this only for a modified 7 or is it good to do for stock, also?
Old Jan 8, 2003 | 02:54 PM
Mahjik's Avatar
Mr. Links
Arrow
Instead of typing it myself:
http://www.pettitracing.com/sections/Protek-R.html
Old Jan 8, 2003 | 03:13 PM
BoostCrzy's Avatar
Doritos on a toothpick
i use lucas oil (they call it fuel system lubricant)...every fill up....seems to have desired qualities for rotaries....
Old Jan 8, 2003 | 03:22 PM
RonKMiller's Avatar
Blow up or win
4 oz. of synthetic 2 stroke every full tank for me. Been doin' it for the last 5 years out of 10 years of ownership.
No drawbacks that I am aware of and it is supposed to make your engine last up to 30% longer. I would think that it would help it run cooler as well, although I do worry about changing the a/f ratio a little. So far, so good!
I personally think the price of Protek R is outrageous. I use any synthetic 2 stroke I can get my hands on by the gallon and keep a small measured plastic bottle in my bin.
Old Jan 8, 2003 | 06:27 PM
ArchangelX's Avatar
Thanks, Mahjik.
Old Jan 8, 2003 | 08:23 PM
Flybye's Avatar
It's never fast enough...
I use mobil 1 Synthetic premix oil.
Mobil oils have always been one of the best burning oils out there leaving almost no deposits. I trust their stuff.
Old Jan 8, 2003 | 08:40 PM
HDP's Avatar
HDP
Please explain the method of pre-mix. Do you mix a quart of oil to a gallon of fuel and then introduce 4 oz of the mix for every fill-up? Or do you pour 4oz of oil straight in the tank at every fill-up? Couldn't you just use 4 oz of diesel fuel for every tank of gas? I'm just throwing things up, I have no idea what is correct.
Old Jan 9, 2003 | 03:28 AM
just dont care.
no wonder FDs got a bad wrap for having bad engines.
Old Jan 9, 2003 | 06:33 AM
Rated R1's Avatar
Oji San
You pour 4oz of oil straight in the tank at every fill-up. Before you put in the gas. That way it mixes real nice.
Old Jan 9, 2003 | 08:59 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Yup been doing it for about a year and love it!
Does anyone else get a lot of smoke on startup when you let your tank run really low? I never run it low on purpose, but did a few times and there was quite a cloud... Other than that it never smokes more than just a hair...
Anyway, after I first started to premix I noticed a difference in idle and response... and I just kept doing it.
Old Jan 9, 2003 | 12:16 PM
HDP's Avatar
HDP
Then why do people use MMO and Protek-R? Wouldn't it be less expensive just to use regular oil?
Old Jan 9, 2003 | 01:59 PM
GsrSol's Avatar
Z06 powered FD
2 stroke oil is suppose to mix with the gas, motor oil is not.
Old Jan 9, 2003 | 03:07 PM
i get a ton of smoke even w/o premixing.
Old Jan 9, 2003 | 05:21 PM
DavidDeco's Avatar
I have more fun than you.
Been doing it for 6 months since my rebuild. Using Protek from Pettit still since I ordered a huge batch. May try MMO when I run out.
