A few questions now that i have pulled my injectors..
Old Jan 4, 2003 | 07:59 PM
StinkyFatPig's Avatar
First off, are the upper and lower injectors exactly the same and it doesnt matter if i mix them up by accident?
the gasket between the top intake manifold and bottom part of it is still perfectly intact and stuck on the bottom peice.. will it still seal perfectly if i just keep it there and not bother with a new gasket? I know you should always replace gaskets but eh.. one less trip to the mazda dealer...
aswell, where the oring is on the bottom part of the lower injectors had alot of gunk on it.. is that just build up from dirty gas over the years? or could that have been a problem with something.. im not sure what but something..
lastly, what kind of shops will clean and test injectors.. I see that alot of people send them to these shops, but I would like to take it to a shop localy because of shipping costs into the US is alittle more expencive, and it takes more time than i want to give up..
Old Jan 4, 2003 | 08:33 PM
Ashitaka's Avatar
yes, the prim and sec injectors are the same.
better to get new gaskets while you're at it. i wouldnt want to take the UIM and LIM when i have them together again
sorry, cant help if you're in Canada, i'm in US
Old Jan 4, 2003 | 10:18 PM
Hey, do you have to replace the air bleeds? If so, how many are there?
Old Jan 4, 2003 | 10:28 PM
BlackRx7's Avatar
Daily Domestic Killer
is this N/A or TII, I took the UIM and LIM off my 89 GTU without replacing the gaskets, but I also use a copper gasket sealer, FYI I didn't replace anything and put it together and every thing worked fine, there are places you can send your injectors to get them cleaned, what kinda problems have you had? if its a hesitation most of that can be solved by regrounding the battery.....
Old Jan 4, 2003 | 10:50 PM
SaabGuy's Avatar
While you have it apart, replace the fuel lines. Only like a 50 centimeters worth under there.
www.injector.com
you can replace all the orings and stuff too.
Old Jan 4, 2003 | 10:54 PM
Ryde _Or_Die's Avatar
When you have it apart just replace everything. New fuel lines, all new o-rings and grommets for the injectors, if you have the money get a new pulsation damper. Its worth the money to be safe. Also get the gasket, its only $3.00 from Mazdatrix.com.
Project84's Avatar
Open up! Search Warrant!
The stock primary and secondary injectors have the same flow rate? I didn't know that.
Old Jan 4, 2003 | 10:59 PM
Yep, 550cc or TIIs and 460cc for NAs.
Old Jan 4, 2003 | 11:47 PM
RexRyder's Avatar
on my tii the secondary flow more than the primaries.
Old Jan 4, 2003 | 11:48 PM
NZConvertible's Avatar
I'm a boost creep...
I'll second that. I removed my UIM today (for injector cleaning) and it's not a job I'd want to do twice because of a $5 part. It's also worth replacing all those stupid, crappy hose clamps.
Old Jan 4, 2003 | 11:56 PM
So you don't have stock injectors anymore.
Old Jan 5, 2003 | 12:44 AM
where do you get the fuel lines? I didn't see anything on the injector.com site.
Old Jan 5, 2003 | 01:02 AM
IM going to take a few of the hoses cause alot of them where very tough to get off and some look pretty damaged and the stuffs cheap.. the injectors o-ring kit is something that is going to have to be replaced.. I dont want those things blowing anytime soon.. and a few of them are very hard and brittle, i assume just over time they hardend up...
someone asked what my symptons where to clean the injectors, the car is flooding heavely.. so this is a start.. and i just wanted to take the top end off to have a better look at the rot setup.. Ive never worked on one before i bought this one..
Old Jan 5, 2003 | 01:08 AM
oh yeah, its an 86 NA GXL
Old Jan 5, 2003 | 01:49 AM
You can buy fuel line at any local auto parts store. Just be sure its for fuel and not vacuum hoses.
You don't have to get everything off the internet y'know...
Any autoparts store will sell fuel hose. Just make sure you get high pressure hose suitable for fuel injection, not normal fuel hose.
Old Jan 5, 2003 | 02:10 AM
88 SE's Avatar
I bought the O-rings on the big cabinet of parts they have. They are called like O-TITE or something. THey are made from BUNA-N so they are just as good as mazda o-rings. The best part is you can get like 10 for $2. Just bring and old o-ring with you to match the size.
Fuel line too can be had at almost any parts store. Make sure you get fuel injection line.
PS: I bought the rebuilt injectors from Nopionline.com. they came with a 1 year warranty and there were $30 each. To have them cleaned would be $25 each so the extra 5 is worth it to get rebuilt and warrantier injectors. Nopi carries both turbo and non turbo and high and low impedance injectors for our cars.
Old Jan 5, 2003 | 11:44 AM
I have been wondering this for some time..
WHat exactly is the diffrence between low impediance and high impediance?
Old Jan 5, 2003 | 01:27 PM
ERAUMAZDA's Avatar
Does any company sell Nice fuel rails. Specially for the rail under the throttle body. For 460cc and 550cc. If not can I remove the PD and attach a fuel regulator to it.
BTW I have a 88 vertible
Old Jan 5, 2003 | 04:30 PM
88 SE's Avatar
Simple answer would be low = low resistance. 86 - 87 models used these.
high ones have high resistance and the 88-91 used those.
The main difference is just the amount of resistance the injectors have. Running the wrong ones can burn up your ECU.
Old Jan 5, 2003 | 10:23 PM
RexRyder's Avatar
no my injectors are stock. the secondaries jus flow more than the primaries for some reason. i found this out when i was cleaning the injectors myself. I made a funnel, put it ontop of the injector, and ran furl injector cleaner thru it, while pulsing the injector w/ my car batt.
Old Jan 5, 2003 | 10:27 PM
RexRyder's Avatar
I have a 88tii and my injectors are hi impedance (hi resistance). so some S4's do have hi impedance.
Old Jan 5, 2003 | 10:33 PM
88 SE's Avatar
ya like i said, 88-91
Old Jan 5, 2003 | 10:39 PM
dr0x's Avatar
pei > caek
They switched half way through 88.
Old Jan 5, 2003 | 10:41 PM
RexRyder's Avatar
oh ok my mistake
