R.I.P my little air pump
Old 12-19-02, 07:20 PM
Quivver's Avatar
Well it looks like my air pump has died, but the car drives like crap now, its really jerky at low RPM and the 3k hesitation has gotten real bad are these normal issues when a air pump goes bad? Also if I want to remove the air pump and get a pully set then I need to get a mid pipe and if I get a mid pipe then I need to get a new ECU like the PFC and if I get the midpipe with the PFC I'll still probaly get boost spikes right? and is it easy to correct boost spikes with a pill and not having to port the wastegate?
Old 12-19-02, 07:37 PM
built my own engine
93BlackFD's Avatar
undo the connection at the top of the airpump..it's electrical, it won't let the clutch engage so your car won't turn on the airpump, it will just spin and do nothing
works like a charm
Old 12-19-02, 09:50 PM
Mr. Links
Mahjik's Avatar
The problem with open exhaust is usually boost "creep". Boost spikes you can usually control with adding the Home Depot Boost control.
Take a look at the following thread for options on controlling boost creep:
https://www.rx7club.com/forum/showth...hreadid=140920
Keep in mind, that not all cars experiece boost creep/spikes (for one reason or another). So you may not have any bad effects from an open exhaust, but it never hurts to be prepared for what you might need to do to control it.
Old 12-20-02, 08:11 PM
Quivver's Avatar
Thanks for the info guys, but is a bad idle being caused by the faulty air pump?
Old 12-20-02, 08:35 PM
93blackrx's Avatar
I wouldn't worry about the pump, I would worry about the cat getting gumed up with unburn't gases. Does the pump still work without the elecerical connection? My advice: get a pulley kit.
Matt
Old 12-20-02, 08:38 PM
Mr. Links
Mahjik's Avatar
Yes, the stock ECU expects the air pump to be there. If the air pump is disconnected or not functioning, then your idle will be bad (it will feel like the car is going to die).
Old 12-20-02, 08:45 PM
93blackrx's Avatar
so what about when you get a Pulley Kit? How do you stablize the ilde? ECU?
Cheers/drink up, Matt
Old 12-21-02, 12:58 AM
Bann3d. I got OWNED!!!
RX7 RAGE's Avatar
I just installed my greddy pulley kit and now it fluctuates badly at idle. Will plugging the pipe that the airpump connects too help? It blows air out and does not suck air in. I put my hand over it to cover it and it smoothened out the idle. Thanks!
Old 12-21-02, 01:16 AM
Speed Mach Go Go Go
GoRacer's Avatar
I McGyver'd the airpump's tube connection (to the Cat')with duct tape and the tube on the air filter holder thing/pipe/dealabob (that connects to the air pump). The air pump is removed, using a Greddy pulley kit and belt from K2RD. I noticed a bad idle at first but now it's normal. I don't know how much i'm shortening the life of the Cat'.
Old 12-21-02, 01:19 AM
RX7 RAGE's Avatar
so you just blocked off the pipe and your idle is fine? I guess I will try that tomorrow. Do you have an upgraded ecu?
Old 12-21-02, 01:25 AM
Speed Mach Go Go Go
GoRacer's Avatar
I think it took a week for the idle to go back to normal. I'm not sure if reseting the ECU is the fix (maybe the new O2 sensor) but I don't have idle problems (exempt maybe a stumble or two when cold) anymore. I also pluged/covered the hole to the air filter that previously had the rubber tube going to the air pump. Yes, I have a Pettit ECU.
Old 01-02-03, 12:56 AM
that's JDM tyte yo!
dubcaps's Avatar
quick question. since my airpump's electrical connection is already disconnected would eliminating the airpump with the greddy pulley kit do anything to my idle?
-stephen
Old 01-02-03, 01:07 AM
half past twelve's Avatar
No...I wouldnt think so
Old 01-02-03, 01:16 AM
that's JDM tyte yo!
dubcaps's Avatar
i wouldnt think so either, but better safe than sorry. =D
-stephen
SakeBomb Garage
Vendor Classifieds
08-09-18 05:54 PM
Frisky Arab
09-04-15 06:17 PM
rotor_veux
09-03-15 07:10 PM
Quick Reply: R.I.P my little air pump
