Mounted the oil cooler, does this look ok?
Well, I decided I need to get this thing working ASAP due to my ever increasing oil leak, so I went and got some hardware to mount the cooler. The pictures are pretty self explanitory. I used two 1/8"x1.5"x6" sections of aluminum angle stock. I used aluminum mainly cause its lighter, and easier to work with. I had to do this at my appartment, and all I had was a hacksaw and a 3/8" drill. Otherwise, it would probably look nicer. Oh well, no matter. No one is really gonna be looking down in there anyway. I really would appreciate some feed back, as Im worried that it might block too much air or something...My electric fan keeps it oh so cold under there anyway, but its nice to have some feedback anyway .
~T.J.
PS - You can also check it out at the link in my sig. Page 13 .
~T.J.
Airflow is my life
Originally posted by Manntis
I can see how the coolar is mounted to the brackets, but not how the brackets are mounted to the frame.
Placement looks good though.
Airflow is my life
Man wassup? I havent been able to access this board for 4 days?????
Anyway, looks good TJ but for one thing. Air takes the path of least resistance right? So wouldnt it tend to go around the cooler? I'm mainly speaking of when the car is stopped. At speed, you'll prolly have enough airflow. I mounted mine right up against the radiator so my electric fan HAS to pull air through it. You might wanna think of putting a piece of rectangular sheet metal to act as a sort of duct. One on top one on bottom from the cooler to the face of the radiator. Just a thought. Maybe invest in an oil temp gauge so you can monitor it for any problems b4 they roach a motor. Cheap insurance. Even an autozone (Sunpro) cheapie water temp gauge ( I use a mechanical sunpro water temp gauge on my racecar) would work.
Trending Topics
Maybe some rubber sandwiched between the cooler and the brackets you made? To help with vibrations getting to the cooler.
That looks like it is going to make running the oil lines more difficult.
~T.J.
Airflow is my life
Hey TJ, heres a great link from Aeroquip. will answer all your Q's about AN fitting's/hoses, etc.......
http://www.aeroquip.com/pages/lit.html
Tennis, anyone
Thats good advice to shock mount the cooler. Instead of just rigid mounting. for cracking, rubber washers, even from a garden hose will work, better then nothing. your gonna reinstall the piece of metal that goes over where your cooler is now, right ?. i like how it can be seen from the front of the car too.a good place to mount it.up from
where they can get damaged. i'd like to move mine,,,soon.
add to cart
on
My aftermarket replacement one (same as OEM, but raw aluminium instead of black) is visible from the front, but being tucked so far back it's only visible if you crouch and peer in...
I wonder, though, why not mount your cooler the same way it is in an SE?
I can has a Hemi? Yes...
Well, thats a good point about the stock mounts being rubber...I will definatly get on that.
Thanks for the link Carl.
Also, I didnt look into how the stock -SE cooler was mounted, and I did this real quick and easy. And as Manntis said, you cant see it unless you croutch down and look in. When I took that picture, I was actually laying on my stomach. Its pretty far in there.
~T.J.
~T.J.
