Question about removal of plastic insert in front scoop.
Old Nov 10, 2002 | 11:34 AM
Brentis's Avatar
Can someone detail how to remove the right side plastic insert? Looks like there is a hook-type holder but even then it looks pretty secure..
Appreciate the help!
Old Nov 10, 2002 | 01:12 PM
Lost Time's Avatar
Chimera Driver
It just knocks right out. No fasteners, just be forceful.
Old Nov 10, 2002 | 01:39 PM
radkins's Avatar
Does this cover really serve a purpose? I removed mine cause a bird flew in there and was starting to smell, but havent put it back yet.
Old Nov 10, 2002 | 02:16 PM
Brentis's Avatar
But does it go back in after using the forcefull apporach? I want to cut a 2 1/4" hole in it for my diy intake.
thanks for your reply
Old Nov 10, 2002 | 02:20 PM
Lost Time's Avatar
Chimera Driver
Yeah, it just snaps in and out. It's not a one-time deal.
Old Nov 10, 2002 | 02:47 PM
FDjunkie's Avatar
I think these are just decorative pieces anyway. Don't they vary in size between models/years? Here's a shot of the driver's side from my '95 PEP. I tried to take a picture of what holds these in place, but couldn’t get my small digital camera back in there far enough. Maybe from below with the undercover off?
Old Nov 10, 2002 | 02:50 PM
GsrSol's Avatar
Z06 powered FD
There are metal clips that hold it in so be sure to keep those. But yea, just knock it out.
Old Nov 10, 2002 | 04:36 PM
Scorpio's Avatar
If you're talking about the plastic pieces in the radiator scoop section (ie, not the small side scoops for the oil coolers), these do serve an important purpose: they force all of the air to go through the radiator and not escape through the sides. So, these are actually a relatively important part of the cooling system.
Old Nov 10, 2002 | 08:38 PM
CantGoStraight's Avatar
What's your point ?
If you have any thing but an R-1 or R-2 model then it's in there because you only have one oil cooler (on the drivers side. You can remove it, drill your hole and reinstall it....don't loos the clips and you can put it back in.
Old Nov 10, 2002 | 08:48 PM
GsrSol's Avatar
Z06 powered FD
I'm confused? If you're talking about the 2nd oil cooler pocket, you can just knock it out. If you're talking about the little ones on the side of the main opening, yes leave those but they are a bit harder to take out.
Don't forget about rain issues and where you locate it. If you're running a tube down to where the 2nd cooler would be, you can just drill holes in the plastic insert which will help keep debris and water out but still get enough air.
Frisky Arab
13
Aug 18, 2015 05:30 PM
Leeroy_25
Aug 17, 2015 12:53 PM
