Looking to replace my R1's bushings...
Old Nov 7, 2002 | 09:31 AM
Question Looking to replace my R1's bushings...
It appears that Energy Suspensions does not have a kit for the FD. Are any good quality ones available? Also, how much of the install is a PITA? I read last night that one technique is to take a torch to your stock bushings and burn the suckers out. Not sure if that's a good idea or not...
thanks guys--
Old Nov 7, 2002 | 03:13 PM
DamonB's Avatar
Ho-hum. As usual, call me and I can tell you everything you need to know
Only bushings available are stock and Jimlab's (now sold through N-Tech I think).
It takes no torches to remove any of them, actually it's not hard at all. The pillow ***** press out as do all the a-arm bushings. I stole Max Cooper's method and made a simple press with great big sockets and long bolts, works fine and is simple.
Old Nov 7, 2002 | 03:54 PM
Cool
Awesome! I guess you just volunteered to help me, Manute
Oh, and if my Victoracer's aren't delivered to Kan's by midnight, I will give you the beatdown of your life ! The fact that I haven't paid for them yet means nothing
Love,
Spud
Old Nov 7, 2002 | 04:57 PM
DamonB's Avatar
And how are we to do this when you live in BFE? Hell, Steve's is BFE! Check out Max's site for the rear pillow *****. The rubber bushings in the a-arms and the trailing links work essentially the same way.
Do you not own a repair manual???
Max Cooper's Do It YoSelf pillow ball replacement
Old Nov 7, 2002 | 05:28 PM
Oh, I do. It's much more fun to **** you off though
Old Nov 7, 2002 | 05:45 PM
Cheers!'s Avatar
Former Rx7 *****
Damn... Maxcoopers's write up is amazing... i never thought of doing it in that way.
any write up for replacing ball joints as well?
Old Nov 7, 2002 | 06:19 PM
maxcooper's Avatar
WWFSMD
You need new control arms for the front lower ball joints. I know myself and probably dozens of other people in the FD community are hoping that someone will make some tubular arms with replacable ball joints. Or at least make them available in the US.
-Max
Old Nov 7, 2002 | 06:49 PM
ArchangelX's Avatar
Where do you get new control arms from? Mazda OEM?
Yeesh...lol...I was planning on replacing the bushings, but I've never replaced a control arm before. I imagine it's not too difficult..but can it be a pain to get back in place?
Old Nov 7, 2002 | 08:26 PM
Cheers!'s Avatar
Former Rx7 *****
max,
i have a FC, and they are replaceable...i didn't know the FD couldn't.
i was hoping for a nice little write up like your bushing write up for replacing ball joints
Old Nov 7, 2002 | 08:36 PM
maxcooper's Avatar
WWFSMD
Well, which ball joints do you mean? There are lots of different bushings in the suspension (20 rear + 14 front, not including steering or sway bars). Many of them are technically ball joints, but the front lower and upper ball joints are the ones normally called "ball joints". Replacing a lower control arm is not majorly difficult. You have to remove it to install the other bushings anyway.
Here's a list of bushings (with annotations):
Front:
1. Lower control arm @ body, leading (Unobtanium)
2. Lower control arm @ body, trailing (Unobtanium)
3. Lower control arm @ shock
4. Lower control arm @ upright (ball joint)
5. Upper control arm @ body, leading (Unobtanium)
6. Upper control arm @ body, trailing (Unobtanium)
7. Upper control arm @ upright (ball joint)
Rear:
8. Toe link @ body (M2)
9. Toe link @ upright (M2)
10. Trailing link @ body (M2, Unobtanium)
11. Trailing link @ lower arm (pillow ball)
12. Lower arm @ body
13. Lower arm @ upright (pillow ball)
14. Upper arm @ body, leading (Unobtanium)
15. Upper arm @ body, trailing (Unobtanium)
16. Upper arm @ shock (Unobtanium)
17. Upper arm @ upright (pillow ball)
-Max
Old Nov 8, 2002 | 08:04 AM
DamonB's Avatar
It's now dinner, beer AND dessert.
Old Nov 8, 2002 | 08:18 AM
Cool
Chicken McNugget Happy Meal, Milwaukee's Best Ice Light, and a Whistle Lollipop. And a swift kick in the nuts
Old Nov 8, 2002 | 03:31 PM
DamonB's Avatar
Hmmmm. What toy will my Happy Meal come with?
Old Nov 15, 2002 | 04:28 AM
jimlab's Avatar
Super Snuggles
Don't forget Mazdaspeed's "40% stiffer" rubber bushings.
And FYI, my bushings will no longer be sold through N-Tech or the "other" place...
Old Nov 15, 2002 | 04:50 AM
GoRacer's Avatar
Speed Mach Go Go Go
Search for Inukai + Bushings = quote below
There are tons od bushings in Japan.
Some of the best quality are Mazdaspeed, AutoExe and RE-A.
There are so many bushings.
for example, motor mounts
1. Steel (AutoSelect, Axia)
2. Aluminum (RE-Amemiya, Okada Eng)
3. Delrine (Pan Speed)
4. Polyurethene (Ksp Eng)
5. Hardest lubber (MazdaSpeed)
6. Harder rubber (AutoExe)
Of course #1 is the hardest and #6 is the softest.
Old Nov 15, 2002 | 08:00 AM
inukai's Avatar
Thank you GoRacer
Spel miss
There are tons of bushings in Japan.
Old Nov 15, 2002 | 03:45 PM
Something that you will no doubt jam up your fourth point of contact .
On a more constructive note--Jim, do you still sell your Super Duper Unobtainable Bushings ?
Rich
t-von
Sep 10, 2015 01:56 PM
BLK 93
11
Sep 9, 2015 10:56 AM
Frox
Sep 8, 2015 08:36 AM
Enzo1944
Sep 6, 2015 08:57 AM
