Greddy elbow for the TII
Old Oct 27, 2002 | 08:18 PM
Tim Benton's Avatar
FD title holder since 94
Well I went to install the ARC IC I got for the TII, but found I need another piece, the Japanese market greddy elbow for the TII, which comes out toward the shock tower, unlike the stock one which comes out toward the firewall.
Anyone know how I can source one out or purchase one if a known seller has one?
BTW, the ARC IC fits almost perfectly under the rubber seals on the hood.
Thanks,
Tim
Old Oct 27, 2002 | 08:41 PM
fcturbo2's Avatar
Re: Greddy elbow for the TII
Thanks,
Tim
http://www.rxengineering.com/
They are located in Australia.
Old Oct 27, 2002 | 08:47 PM
Tim Benton's Avatar
Just curious since I'm still learning about the TII, since I've only had it for about 6 months now (had a 91 N/A for 5 years, and my FD for 8 1/2 years), doesn't the TII t-body inlet have hoses attached to it, unlike the one that RXengineering makes ( i did a search and saw that company's inlet
Thanks though for the reply,
Tim
Old Oct 27, 2002 | 10:48 PM
chris-reedtn's Avatar
ho just the intake temp sensor
-Chris
Old Oct 27, 2002 | 11:29 PM
fcturbo2's Avatar
hey have you thought about using the one off the N/A??..There is a guy here that uses it in his TII but had to do some modification. I think you will have to remove your PS or something. I know i will be doing it to my TII since i dont run AC and PS.
Old Oct 28, 2002 | 10:34 AM
Jahoo88's Avatar
to use the NA one u have to cut down your oil filler neck to about 3" in length. Or cut it and weld it at an angle away from under the NA elbow.
Old Oct 29, 2002 | 01:46 AM
fcturbo2's Avatar
Jahoo88 have you done it and if so got any pics???..
Old Oct 29, 2002 | 01:57 PM
RETed's Avatar
As far as I know, Trust/GReddy does not sell this elbow separately, short of buying the entire front-mount IC kit?
-Ted
Old Oct 29, 2002 | 02:18 PM
j9fd3s's Avatar
Community Builder
-Ted
i think thats right.
mike
Old Oct 29, 2002 | 05:58 PM
Tim Benton's Avatar
That bites ***, sell it seperate guys.
Looking at www.jt-imports.com, under the feed section, they have one listed, but with no intake temp sensor fitting. Should I go with the Feed one or get a NA and make it fit? Not worried about the money or time, just ease of installation and other things that might have to be done. Although apparently with either one, I'll have to trim the oil filler neck.
Tim
Old Oct 29, 2002 | 05:59 PM
Tim Benton's Avatar
Does the NA elbow have an intake temp sensor for it, or will I have to make a fitting for it?
Tim
Old Oct 29, 2002 | 06:10 PM
Tim Benton's Avatar
Of the 2 listed, one says 60, the other 70-80, not sure if that refers to mm or not, but I'd assume I'd want the larger of the two for the TII.
Tim
Old Oct 29, 2002 | 07:03 PM
RETed's Avatar
Yep, sounds like diameter inlet to me...
-Ted
Old Oct 31, 2002 | 07:46 PM
Jahoo88's Avatar
There is no sensor in the NA elbow. Its a big diameter too.. . i'll measure it and let you know.
the filler neck is now about 3" long... hard to get to it but it works and the angle is pretty close to perfect.
Old Oct 31, 2002 | 07:48 PM
Jahoo88's Avatar
Th efiller neck is 3" tall i meant.
Old Oct 31, 2002 | 10:03 PM
cymfc3s's Avatar
I Raise Chickens
Old Oct 31, 2002 | 10:15 PM
Cheers!'s Avatar
Former Rx7 *****
what does that elbow do?
Old Oct 31, 2002 | 10:21 PM
fcturbo2's Avatar
CYM thats what i need. Are you selling it?..
Old Oct 31, 2002 | 10:31 PM
cymfc3s's Avatar
I Raise Chickens
Smile
yah, and it comes with a yellow turboII attached to it.
Old Nov 1, 2002 | 08:33 AM
Jahoo88's Avatar
Cheers!, the stock elbow is angled up and back at around 45 degrees. It makes for almost a 180 degree turn when plumbing an fmic. The NA elbow is angled forward. By the looks of it the greddy goes pretty much straight out.
Old Nov 1, 2002 | 09:17 AM
fcturbo2's Avatar
Seth. I PMed you. pls email me back..
Old Nov 1, 2002 | 09:32 PM
Tim Benton's Avatar
I'll pay full price since I was looking first add in some extra as well.
Tim
Where did you get it and can you get another one?
