need help quick; something leaking
Old Oct 4, 2002 | 11:37 PM
Scrub's Avatar
bow leggin'
between 2-3.5k r's there is a high pitched noice coming from my engine. It sounds like a leak and sounds like it's coming from the y-pipe. any common problems this could be?
Old Oct 5, 2002 | 12:00 AM
duboisr's Avatar
Bad O ring , blown gasket (early model had paper ones ) 10 mm nuts need to be re torked holding Y pipe to the turbo ,Y pipe to innercooler pipe leak, ect. ect.
Old Oct 5, 2002 | 12:05 AM
Scrub's Avatar
bow leggin'
So what do i have to do? It sounds like its coming from the intake manifold. Can i still drive the car like this or is it bad?
Old Oct 5, 2002 | 12:33 AM
Scrub's Avatar
bow leggin'
anyone??
Old Oct 5, 2002 | 12:40 AM
Scrub's Avatar
bow leggin'
Okay well i guess no one knows, Or i won't get an answer untill tomrrow. Im guessing that it is the intake manifold, im gonna try taking it apart.
Old Oct 5, 2002 | 02:03 AM
Nathan Kwok's Avatar
You can still drive with an intake leak but take it easy or you risk overspinning the turbos. It'll also confuse the computer so your mixture may be off, so don't do it long term.
Old Oct 5, 2002 | 03:19 AM
check to see if your bypass valve is cracked or did you dissconnect it fron the air box (it does not act exactly like an aftermarket blowoff valve) they bleed off boost at around 1psi if you hold it there??? I dont know try to be a little more descriptive. (is the noise under boost, You wont have possitve boost without a load on the engine (holding the rpms at 3k while the car is parked) it may be an air pump issue thy disconnecting the grey connector and see if the noise disapears. good luck.
Old Oct 5, 2002 | 08:04 AM
Scrub's Avatar
bow leggin'
It happens when im parked and when im driving, but when im under the hood reving it you can hear it just about all the time. It sounds like the engine, just louder.
Old Oct 5, 2002 | 08:30 AM
Scrub's Avatar
bow leggin'
Wahooooo, i found the leak, the hose was busted that connects the air pump to the engine. What a pain in my ***. Now i need to go find a new one. I'll probally just to go mazda and pick one up. Unless it's like 30 bucks.
island fd
Sep 18, 2015 07:59 PM
t-von
Sep 10, 2015 01:56 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
gabescanlon
Sep 5, 2015 12:04 AM
