2nd gen OMP on 3rd gen
use a 13bt (s4) front cover and we can figure out the rest, i think i have all the **** as I had 3 fucked up 13bt (s4s) I might still even have the oil injectors though id recomend getting new ones. They are not too much.
1JZ powered
Greg,
It will be interesting to see this work since a lot of 3rd Gen guys are running Haltech's. If you could get this to work, they'd be able to run Mechanical OMP AND a Haltech...hmmm...
This is not a new idea. There are a lot of people running mechanical OMP's on 3rd gens. I don't think it's neccessary to use a 2nd gen front cover either. **** it. I'm just gonna block it off for now till I can figure this out.
you can have mt front cover if you need the ****. plus i have a few omps laying around.
http://www.rotaryaviation.com/oil_in...p_adaptors.htm
i think you may still have to retrofit this though. can not speak from experience. sorry.
josh i was going to do the 87 omp, but i decided to just block it off until i got car up and running. if i figure it out before you, i will let you know. also, i have many extra pumps if you need them also.
Trending Topics
The link is not working. I have an 88 pump. it looks like a couple of things just need drilled and tapped, but I don't want to ruin my front cover by drilling into something I'm not supposed to.
Greg- are you sure that your front cover will fit up to my block with no problems? It looks to me like I would have to at least change my CAS setup. i don't know if I feel like going through all of this. I have an appointment with KD Rotary next week for some dyno time. I will ask him then. He has done a **** load of these conversions and I'm sure he will have the answer I'm looking for.
It worked this time. I've seen that page before. All that thing does is feed fresh 2 cycle oil to the OMP. It is not an adapter. It utilizes whatever system you are currently using. It sounds like a good idea, but it wouldn't be much different then premixing. You still have to fill up the resevoir every time you fill up with gas unless you have a huge resevoir. Personally, I am running out of room in my engine compartment.
Garfinkle s 2 cycle tank he made holds more than three qts , he has looked into using a mechanical pump in place of the elect, with an adapter for 2 cycle oil.Ido not know what he found out.
