why is my A/f guage always on the last rich bar???
Old Sep 8, 2002 | 08:47 PM
Flinstone Power
my car is a 87 GXL and my a/f guage is allways on the last rich bar no matter what RPM... does this have something to do with my 550cc secondaries?? but even at idle and anything b4 or after 5000rpm its in the last rich bar.. could my O2 sensor be bad.. or could this be b/c i am open header
Old Sep 8, 2002 | 09:12 PM
Scott 89t2's Avatar
SOLD THE RX-7!
why are you runing 550's? probably run alot better with stock ones.
are you running an AFC or anything?
Old Sep 8, 2002 | 09:18 PM
as long as ur car doesnt stink like rich fuel out the exhaust or it doesnt waste a lot of gas.. i wouldnt worry about it... but why go 550 cc secondary on a mostly stock na?
Old Sep 8, 2002 | 09:20 PM
streetraceseven's Avatar
if it is an autometer.... on our dyno we se autometers read full rich when our wideband o2 reads 15:1A/F ratio
Old Sep 8, 2002 | 09:35 PM
DCmina's Avatar
oh crap, I'm installing my Autometer one tomorrow. Anyone else got an Autometer? Does it also read rich all the time?
Old Sep 8, 2002 | 09:58 PM
Flinstone Power
i am running 550cc 2ndaries bc i got a s4 rebuiild with s5 rotors, rb header, ported intake, tb mod, cold air intake, all emmissions bull **** removed, ps removed, and 5/6 port sleeves removed.. ect.. so i got plenty of mods to back up my 550's... so what do i do about my a/f?? i know other guys that have them on there 7's and they work great... should i try a different brand? if so what brnad? thanks Dave
Old Sep 8, 2002 | 10:05 PM
Scott 89t2's Avatar
SOLD THE RX-7!
buy a S-afc and get it tuned with a wide band o2...
Old Sep 8, 2002 | 10:11 PM
billy's Avatar
i have that a/f guage and it works fine. no problems here.
exsept for a very bad Exsaust leak
later
Billy
Old Sep 8, 2002 | 11:43 PM
Juan's Avatar
Im a tall midget.
My autometer worked fine. Dont know how accurate it was but it seemed to be working properly.
Where did you hook up your o2 wire from the gauge to? Did you hook it up to the ecu's o2 wire or did you tap into the actual wire coming out of the o2 sensor?
Old Sep 8, 2002 | 11:50 PM
DCmina's Avatar
Do I have to hook it up in the ECU's O2 wire? That's what the instructions says but the wire is too short.
Old Sep 8, 2002 | 11:53 PM
Scott 89t2's Avatar
SOLD THE RX-7!
as oposed to what? the 02 sensor will be further away then the ecu...
just tap into the wire between the ecu and o2 sensor. anywhere along.
Old Sep 8, 2002 | 11:58 PM
DCmina's Avatar
wait I still don't get it. You tap the wire in the engine bay right where the O2 sensor is right?
Old Sep 9, 2002 | 12:02 AM
maxcooper's Avatar
WWFSMD
I have an A/F meter and it is useful for a couple of things (idle mixture, see when you are in closed loop, pretend you are driving KITT, etc.) but they aren't accurate enough for tuning. It isn't the meter that is at fault -- it is that narrow band O2 sensors just aren't accurate anywhere but at 14.7:1. See this page for more details:
http://www.fjoinc.com/automotive/WBO2details.htm
Yes, it is a wideband sensor vendor, but the information is accurate.
A bad ground or a faulty connection might be responsible for the bad readings you get. Or it could be the sensor.
-Max
Old Sep 9, 2002 | 12:09 AM
Rpeck's Avatar
What R U thinking self?
Tap it at the ECU
Old Sep 9, 2002 | 12:13 AM
Scott 89t2's Avatar
SOLD THE RX-7!
there is a wire that runs from the o2 sensor to the ecu.. it's the same wire. you could tap it anywhere and you would get the exact same reading on the guage...
hell you could put 10 gauges, each 8"s apart alone the whole wire if you really wanted too... and they would all read the same.
Old Sep 9, 2002 | 03:38 PM
Flinstone Power
ya i tapped the wire right off the O2 sensor.. my rb header came with like 3feet of new wire so i tapped the new wire that came with the header to keep my harness clean.. dave
BTW.. my O2 sensor was pretty nasty looking when i put it in the header..
also do i need to buy the auto meter wide band o2 sensor?? if so will this ork good with it in place of the stock narrow band one??
Old Sep 9, 2002 | 03:58 PM
Scott 89t2's Avatar
SOLD THE RX-7!
the you should probably change it...
I don't even think they make one... it's a sensor and gauge together. they cost $1000+.. you don't buy one, you pay a shop to tune it for you with theirs. but unless you have a s-afc or something you can't tune it. if you are running 550's you should have something to tune them with...
Old Sep 9, 2002 | 09:21 PM
Flinstone Power
ok thanks guys... i will go to mazda thursday and order a new one for a $100something bucks.. Dave
Old Sep 9, 2002 | 10:00 PM
DCmina's Avatar
A new O2 sensor? I got a Bosch one at AUtozone for $30.
I tried to install it today, but I still can't find that grey wire!
Anyone wanna tell me exactly which one to put it in?
BTW I took the pic from your site Scott 89t2.
thanks
t-von
Sep 10, 2015 01:56 PM
gabescanlon
Sep 5, 2015 12:09 AM
