removal of door panel on an fd
Old Sep 4, 2002 | 05:50 PM
af908's Avatar
Hey does anyone know where there;s a site i can find out how to remove my driver's side door panel and center counsol (to put on a new shift boot) or can one of you guys please explain it to me? i don't wanna break anything so i wanna make sure i know the right way to do it.
Old Sep 4, 2002 | 07:37 PM
R Xplicit's Avatar
the shifter console has about 6 snap pieces on it. simply pull on it gently and they will pop out. panel pullers work great.
as far as the door panels are concerned.....there is a removable tab in the latch pocket. under it is a phillips screw. remove it. then, there are 3 or 4 phillips screws around the inside, underside, and backside of the panel itself. remove them, and lift up on the panel. it should slide right out. when re-installing it, ba careful to make sure that the window trim is in properly, or it will not fit right....
-louis
Old Sep 4, 2002 | 10:27 PM
poss's Avatar
Slower Traffic Keep Right
I will add that the bottom and front and rear edges need to be pulled out slightly before lifting the door panel.
Old Sep 5, 2002 | 05:54 AM
Rated R1's Avatar
Oji San
I would also add that you need to remove the panel that covers the external door handle the small triangle piece near the rearview mirror.
Old Sep 5, 2002 | 01:51 PM
rallimike's Avatar
Anything different about the passenger side? Mine won't come off.
Old Sep 5, 2002 | 02:36 PM
GtRx7's Avatar
The passenger side is similar to the drivers side except one VERY Important thing. (if you have power windows). Behind the power window switch is a screw that need to be removed. Pry out the switch and it should pop out. Then look into the hole in the handle and you will see a phillips screw. Lastly there is also the screw in the door handle cup that needs to be removed and one large screw hidden behind a plastic cap. The cap is located below the handle about 6-8 inches down. Remove the cap and there will be a phillips screw. Hope this helps
Most people don't know about the screw behind the window switch and end up ripping out the handle from the door panel.
Old Sep 5, 2002 | 03:35 PM
rallimike's Avatar
Thanks. Got it.
Old Jan 26, 2003 | 12:13 AM
do u guys have like diagrams?
Old Feb 12, 2003 | 02:45 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
yeah that power window switch confuses alot of people. its actually really easy though. i also pulled the plastic cover that covers where the outside door handle is. after u pull the center console theres 4 screws holding the boot on, very simple.
runner83
1st Gen General Discussion
16
Aug 26, 2015 05:16 PM
