FD dyno results from last night
Old Aug 23, 2002 | 11:29 AM
ZeroBanger's Avatar
I would like to attach my dyno sheet, but when I attach a pic, it just shows up as a link...how do I attach as a pic?
Old Aug 23, 2002 | 11:46 AM
R Xplicit's Avatar
go to the body of the massage, and cut and paste the link. it would need to be hosted ont he internet to work though. here's how it should look
[IMG]insertedlinktopicture[/IMG]
Old Aug 23, 2002 | 11:48 AM
R Xplicit's Avatar
woops^^^i guess that i illustrated it too well....
brackets [] with IMG before the cut an pasted link and brackets[] with /IMG directly after the pic. no space or anything...
Old Aug 23, 2002 | 11:52 AM
matty's Avatar
what did your car make?
Old Aug 23, 2002 | 11:57 AM
ZeroBanger's Avatar
Here is the dyno sheet....
Old Aug 23, 2002 | 11:59 AM
matty's Avatar
262 rwhp @ what psi?
get a midpipe!!
Old Aug 23, 2002 | 12:00 PM
amp's Avatar
amp
old yella
at what boost setting....
and what was the temp....
Old Aug 23, 2002 | 12:02 PM
ZeroBanger's Avatar
get a midpipe!!
I guess I should clarify, I had 5 runs and aborted 2 of them. my intercooler was so hot I could not touch it. We cooled the car down for 20 minutes and ran it again. I freaked out at the transition cause it hit 14 psi and he aborted the run. The guy running the dyno said I would have hit 280 easily. The next run my IC was a heat sink again and did the 265. I did not change the boost for the last run, it hits 14 psi at transition and then went down to 12 ish PSI.
Anyone else find it odd that my power peaks so early and holds till the red line?
Also they shop had a small fan that was about 4 feet away from the car. it was worthless. It was 265.8 HP around 12 PSI (I set my power FC to 80 and 80 for the secondary turbo. My water temp was 108)
David
Old Aug 23, 2002 | 12:07 PM
matty's Avatar
damn thats a hot *** water temp!
get a midpipe...lol..no seriously mp make so much more power...i ran an fd with same mods as mine but a high flow instead of a mp...we raced from 55mph..i RAN away from him...!
Old Aug 23, 2002 | 02:41 PM
Wargasm's Avatar
Weird Cat Man
I added your dyno to my page at www.catenet.net/dyno.php
Old Aug 23, 2002 | 03:50 PM
JspecFD's Avatar
Re: FD dyno results from last night
Just attach the image and then get the link address from where the forum hosted it. Then, just edit your message adding in the address for the pic like so:
Old Aug 23, 2002 | 05:09 PM
MazdaMike's Avatar
whaen u run a dyno hoe many fans do u normally have or does it carey and can u just channel a fan directly to the intercooler port?
Old Aug 23, 2002 | 05:15 PM
ZeroBanger's Avatar
it was a small fan maybe 30 or 32 inch, sitting about 4 feet away. it wasn't even a breeze. I guess it depends on what shop you use.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Rotate86
May 18, 2018 02:44 PM
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
Jmpabon93
Sep 30, 2015 04:57 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
