New T66BB pics!
Old Aug 22, 2002 | 09:35 PM
machinehead's Avatar
kortez
New T66BB pics!
Just picked up my new T66BB(double BB) from Innovative today! Cant wait to put it on and run it!
Old Aug 22, 2002 | 09:36 PM
kortez
another pic.
Old Aug 22, 2002 | 09:37 PM
kortez
last one.
Old Aug 22, 2002 | 09:40 PM
kortez
I am planning to run it on my XS cast manifold but I was thinking about have SFP make one later and switch to that. What do you guys think? Are there any bennifits to a nice tubular stainless manifold other than looks?
Old Aug 22, 2002 | 10:40 PM
the_glass_man's Avatar
Will u do me a kindness?
Wow thats nice, what specs did you get on it???
Old Aug 22, 2002 | 10:41 PM
If you blow on it does it move???
Old Aug 22, 2002 | 11:31 PM
mako's Avatar
very nice does it fit ok with the xs manifold?
my current turbo with the hks cast manifold is like 1mm from the frame rail on the compressor side
i think for a street car the cast is fine. i would think the runners being closer to the motor is better too. most other tubular ones you see are higher up. better clearance tho. I am not an engineer tho
James
93 mb
Old Aug 23, 2002 | 01:04 AM
kortez
Yes!!! The thing is so tight and smoothe.. its incredible!
I hope so... I have the TO4S right now and it is a close fit... maybe another manifold will not be an option? I am still waiting on some exhaust tubing so I can't put it in until next week some time. The discharge outlet is 3 1/2", and my downpipe is 3" so i need to make a new pipe and reduce it down.
Its a Q trim 1.0 devided housing... before anyone jumps in and says "that's too small", let me just say, i know, but I wanted to try it anyway. I am running this TO4S(60-1) with the same size and its a P trim. The Q should flow better so I am going to try it and see what happens. If it starts to choke up I will go for a 1.15. If it works with the 1.0, then I will have a very fast spooling, high flowing turbo that I can push to 25psi if I want.
Old Aug 23, 2002 | 01:55 AM
Jetlag's Avatar
[QUOTE]the_glass_man If you blow on it does it move???
That sounded so
Nice turbo, must have set you back some $$$$. Love that V-band on the turbine discharge. I'm running 60-1 with P-trim. Boy its time for me to save up again.
Old Aug 23, 2002 | 06:24 AM
ErnieT's Avatar
Living life 9 seconds at a time
The tubular flows better and is lighter, but the cast manifold is better for the street and is less prone to cracking, unlike the tubular.
Old Aug 23, 2002 | 08:05 AM
soul assassin's Avatar
GTR eater
HPI has nice SS manifolds that are pretty much crack resistant i have had mine for over 3yrs of everyday use and not one crack
Old Aug 23, 2002 | 12:50 PM
Greg's Avatar
[QUOTE]Originally posted by Jetlag
That sounded so
Innovative turbos are the ****!!! Im a dealer for them. Believe it or not they will spin when you blow on it. I had a customers T72 Dual BB here and you can tap it and it will spin and spin and spin. They are expensive but worth the loot imo.
Old Aug 23, 2002 | 03:03 PM
Perfect turbo...600+rwhp...no problem. 430+rwhp on pump gas @ 14 psi. all day long. 17-18 psi almost or just under 500 rwhp on pump gas. Have fun!
Old Aug 23, 2002 | 04:11 PM
are they better than the dual bb gt series turbos? do they spin easier than the gt's? how much can you get the gt80 dual bb, greg? i asked innovative and they quoted me 3500.
Old Aug 23, 2002 | 04:24 PM
Greg's Avatar
Jesus!!!!!! The GT80 is a HUGE turbo, do you plan on running super high boost? They also use that wheel in the thumper series!! You will have spooling problems on a 13b with that turbo! That is definately not a street turbo. The larger GT series turbos are good (what magnus uses) After some investigation on the 35/40 turbo you can realize how small the turbo actually is.
Old Aug 23, 2002 | 04:50 PM
Bucrx7's Avatar
Very nice! How much did it set you back?
Old Aug 24, 2002 | 01:18 AM
kortez
Well, it wasn't cheap, I will say that much. After spending allot of money trying to squeek by with different turbos, I decided to just go for it and get what I really wanted. Innovative is great, good guys, good reputation, and they are the only place I know that does the dual BB larger turbos. After I get it all set up I will post results.
Old Sep 17, 2002 | 11:06 AM
Node's Avatar
What a beauty!
Nice stereo too
Old Sep 17, 2002 | 11:18 AM
presetlimits's Avatar
Old Sep 21, 2002 | 12:03 AM
680RWHP12A's Avatar
nice turbo!!!! im a dealer for innovative, those guys really know thier sh....t , ... i could get a gt80 from them starting at 2,800
Old Sep 21, 2002 | 03:45 PM
jspecracer7's Avatar
1JZ powered
I would figure a Q trim 1.0 would work just fine with that turbine. Why would anyone say it's too small?
Old Sep 22, 2002 | 01:17 AM
kortez
I thought it would, and will work just fine, that's why I got it. It just seems that the general concensus on this board is bigger exhaust housings are better although I know some people making very good power with smaller than 1.0 on the hot side. It seems you have two seperate ideas about exhaust housings, you got the guys that say you have to go large to make power and the guys that say that's B.S. and you are just loosing response and adding turbo lag. I thought I'd try somewhere in the middle and go from there.
The car is going together smoothly so I should have it running soon and will be sure to report on my first impressions.
Old Sep 22, 2002 | 01:20 PM
chohakai's Avatar
hooking up the downpipe to that turbo
I notice that the turbine housing outlet is not a standard 3" turbonetics outlet that allows their V-Band kit to be used. It looks like a 3.5" outlet. How are you going to hook up the exhaust downpipe? I'm interested because I have a similar housing.
Fred
Old Sep 22, 2002 | 02:17 PM
From: Minnesota, now in FL and I dont think I'm goin back
Does inovative have a website?
Old Sep 22, 2002 | 03:55 PM
kortez
http://innovativeturbo.com/
Yes, that is a 3.5" outlet. I am having a custom downpipe made.
