NOS and rotary
The zex uses engine vacuum from a source that is mapped into its brain to regulate nitrous flow and kick the injector cycle up on its specific car make. The box used on a Honda won't work in a Toyota. All that's usable from the kit would be the bottle, lines, thread tap tool and the injector itself. You'll have to buy another injector, guess at the jet size for fuel and buy solenoids for both injectors. And you'll have to buy the relays to run the solenoids. Way too much hassle. Especially since they sell for around $500 new...regarding a traditional wet system, one of the guys in this Forum is running a 100 shot with no problems so far...
You guys should search the second gen forum, there's so many threads about "how much n20 can I run" and such.
Anyway, rotary takes fairly well to N20, provided the install job is good. Wet would be the ideal way to go, it's much safer for your engine. I've heard the best things about the Zex setup (for something like a 50 or 75 shot) because it's cheap (~$500), it's simple to install, and it's a wet system.
Like I said, do a search and you'll find more than you'll want to read. Might want to try looking in the Rotary Performance section too.
I was looking at one of the Holley Sniper N20 kits, and I was wondering if you guys think that it would work on our cars...Its only like $300, so its kinda affordable, but Im not sure how well the system is put together.
~T.J.
The Best ENTRY-LEVEL Nitrous System On The Market!
The engineers at NOS have hit a bulls-eye by designing the finest entry-level nitrous system available today with the NOS Sniper kit. The Sniper is the economical "entry-level" kit from NOS that simply blows away competitive kits. The Sniper was developed to introduce enthusiasts to the use of nitrous at a very affordable price. This system is a safe and reliable street/strip system that fits all popular 4 bbl. applications
The Sniper is a fully adjustable system that is designed to provide from 100-150 extra horsepower in popular 4 bbl square bore or spread bore applications. However, you can get more than you bargained for. In dyno tests conducted by Chevy High Performance magazine the Sniper setup produced an extra 163 horsepower when installed on a 355 CID small block Chevy with torque increased by an astounding 195 ft. lbs.
Sniper kits comes race ready right out-of-the-box with all necessary components, including a distinctive bright orange 10 lb. bottle with the industry standard industrial valve, adjustable plate with jets, solenoids, plus all required lines, hoses, fittings, clamps and a detailed instruction sheet to make installation simple.
Trending Topics
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
