Profec B - How could this be wrong?
Old Aug 15, 2002 | 10:13 PM
mcf's Avatar
mcf
I have read many posts/ instructions regarding the profec B setup... Most say to tap ONLY into the wastegate actuator and this is what I have done for the past 2.5 years. However, I have never been happy with the performance (low power in low gears and very sensitive to weather changes/ boost creep). Yesterday, I did what many say you should never do and tapped both the PCA and wastegate actuator to the profec via a T fitting and the difference is amazing. Boost on both turbos is quick, predictable and dead nuts in every gear - it's awesome. I expected a pretty harsh transition (t-ing the PCA presumably eliminates the prespool), but even that isn't too bad. How could this be bad?
Old Aug 15, 2002 | 11:02 PM
zayrx7's Avatar
the mazda zoom zoom store
what is pca
Old Aug 17, 2002 | 10:14 AM
pca
precontrol actuator
Old Aug 19, 2002 | 07:57 AM
mcf's Avatar
mcf
Nobody have an opinion on this?
Old Aug 19, 2002 | 09:52 AM
mcf's Avatar
mcf
Diagram of install
OK... here's a diagram of the install (at least my interpretation). Hope this helps.
Old Aug 19, 2002 | 10:48 AM
could it be harmfull to the turbos?
Old Aug 19, 2002 | 10:56 AM
mcf's Avatar
mcf
That's exactly what I am trying to find out... but i can't see why it would be catastrophic. It is so much better I think I would stick with it even if it shortens the life of my turbos.
Old Aug 19, 2002 | 11:28 AM
CantGoStraight's Avatar
What's your point ?
Replumbed Profec-B
I have the Apexi AVCR and can tell you this is the way it is supposed to be on my unit. I read some where that tis would be something to try on the Profec-B, just that no one has tried it till now. Looks like it works well (as it was thought it might) Jack
Old Aug 19, 2002 | 11:49 AM
What's your point ?
Replumbed Profec-B
Old Aug 19, 2002 | 12:21 PM
What's your point ?
Sorry for the double post.
Old Aug 19, 2002 | 03:51 PM
mcf's Avatar
mcf
Stats
12lbs at 2,500
11lbs at transition (around 4,500)
12lbs to redline
1st thru 4th gears
dona1326cosprings7
Oct 29, 2015 06:47 AM
pfsantos
Sep 30, 2015 01:29 PM
