Heated O2 sensors?
Old Aug 10, 2002 | 10:43 PM
racer rx's Avatar
Heated O2 sensors?
How many of you guys use heated O2's for normal
street driving? Any bad effects?
And when you heat them?... do you just turn to accesory on? and for how long of a period of time?
jc.
Old Aug 11, 2002 | 01:00 AM
RX7Elmo's Avatar
i think the only heated 02 sensors are the wideband units. You can't just replace the stock 02 sensor with a 5-wire sensor. You need a heater/heatsink,powersource and all that good stuff.
Danny
Old Aug 11, 2002 | 02:39 AM
duboisr's Avatar
you wire the heat wires one pos to a 12 volt engine on source ,the negetive wire to ground. The sensor wire to the ECU .When you start the car the heater in the sensor will heat the sensor up more quickly than the exhaust will, It must be above 600 degrees to work, I just let the car heat my o2 up as the motor heats up Ican wait 3 or4 minutes
Old Aug 11, 2002 | 02:49 AM
racer rx's Avatar
What sensor's are you guys using? I have a Napa auto
parts Ford escort O2... is this what everyone else is using too?
What of these walker o2 sensors http://www.oxygensensors.com/
Old Aug 11, 2002 | 09:03 PM
rotary-tt's Avatar
2 babies - no back seats
I have a heated O2 from Pettit. I think it is from a Corvette. Does not seem to make any difference, even seems to run worse when cold out.
7upra
Mar 25, 2018 11:32 AM
imitek
24
Dec 1, 2015 03:35 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
