FMIC vs. SMIC??
Old Jul 29, 2002 | 07:28 AM
tomaszjc7's Avatar
FMIC vs. SMIC??
I am trying to decide between staying twin or going single. But before i do that i want to upgrade my IC. I was originally goin to go with a Greddy FMIC but when i went to a local rotary shop one of the guys there told me FMIC's suck becasue every time you hit the gas all the pipping has to get re-pressured, causing lag. And with a SMIC there is very lttle piping making it more performance happy... But when you really think about it, isn't the intercooler there so the turbos get cool air, so wouldn't it make sense to put the IC in the frot bumper rather than in the engine bay!?
I'm really not on expert on any of this but that makes more sense to me.. But what if you had a SMIC and vented hood... would that help???
Old Jul 29, 2002 | 07:43 AM
WhiteRXseven's Avatar
I got a SMIC..
And I am wanting a FMIC.
Natural progression with Moding a FD3S is
gonna lead to a FMIC.
SO if you have a choice go with a FMIC
and save yourself the hassle, down the
road.
Old Jul 29, 2002 | 08:56 AM
Mr rx-7 tt's Avatar
rotary sensei
This should help: http://www.scuderiaciriani.com/rx7/intercoolers.html
Old Jul 29, 2002 | 09:11 AM
ttpowerd's Avatar
HARRRRRRRRR
Also search! This has been a big topic a ton of times b4.
Old Jul 29, 2002 | 09:16 AM
ttpowerd's Avatar
HARRRRRRRRR
Why?!? I don't plan on getting a FMIC and I have a SMIC from m2 now. I don't understand, please explain.
Old Jul 29, 2002 | 09:23 AM
Johnny's Avatar
OG
GOD...do a search..this has been discussed plenty of times
Old Jul 29, 2002 | 10:45 AM
3,2,1 FIGHT!
Old Jul 29, 2002 | 11:03 AM
Kahren's Avatar
i am not a girl
stop fuckign telling people to search, if you wasted your time reading the post why not answer the guy, or if you cant answer just click teh back button on your browser.
smic is good for tracking the car, as in road racing not drag, or if you get on it mostly on the highway or higher speeds, because with a smic you need a some flow thru the bumper to let that air cool the intercooler down. if you all u do is drive around town that smic will get heat soak, and when u get on it from the stock all that hot air ill be shoved in your motor, not good. with a fmic the intercooler is almost outside of the car and will therefore be cooler most almost all the time, this is good if you do short bursts. the downside to the fmic is that the air that goes thru the intercooler goes to the radiator after to cool it down, and this will cause your engine to run hotter, especially if you are gonna road race the car. where the smic has its on duct to get the outside air and the radiator has its own. depending on your style of driving you shoudl choose the intercooler accordingly. hope this helps you
Old Jul 29, 2002 | 02:43 PM
tomaszjc7's Avatar
THANK YOU Kahren! Someone finally answered my question.
Old Jul 29, 2002 | 02:54 PM
Indra's Avatar
you can always buy aftermarket radiator to compensate the cooling effect. I think FMIC is always the best choice.
Old Nov 27, 2002 | 08:17 PM
SleepR1's Avatar
Really...even for us road racers?
What about this turbo lag I've read about with the long pipes...the inefficiencies inherent in the longer runs of plumbing, etc....?
Old Nov 30, 2002 | 11:50 PM
rfreeman27's Avatar
You could always go horosintal mount or "v" mount instead. Check them out at www.rotaryextreme.com
Old Nov 30, 2002 | 11:58 PM
black99's Avatar
Lurking..................
And you know what if you would have just searched you not only would have came up with tons of threads discussing advantages/disadvantages of both but you would have kept from wasting forum space with the 100th FMIC vs. SMIC thread ever created..
I still reccomend you search as you'll find tons more info then you have here.
Old Dec 1, 2002 | 12:35 AM
MrKentChu's Avatar
what can you do about the hotter temps if you go with fmic? vertical mount radiator like the shape of an I? how would that help?
Enlighten me please!
kent
Old Dec 1, 2002 | 12:42 AM
Nameless's Avatar
I think the vertical mounting isnt really helping temps, but more for making space for the intercooler.
Old Dec 1, 2002 | 12:50 AM
black99's Avatar
Maybe these will help you figure out somethings you can do to make your car run a bit cooler with a FMIC..
I saw a couple tricks in there dealing with the fans but there might be something else in there.
https://www.rx7club.com/forum/search...der=descending
Old Dec 1, 2002 | 04:12 AM
redrotorR1's Avatar
LS6 Convert
Also, the horizontal IC isn't truly effective without having a vented hood.
But, on the topic of SMIC vs. FMIC, it really boils down to what you plan on doing with the car and how much you're willing to spend on it. FMIC are generally more expensive and require more work (relocating battery, fabbing/cutting pipes, re-mounting radiator). Personally, I don't think the FMIC's are worth the hassle and the plus/minus game doesn't figure well for my purposes.
Old Dec 1, 2002 | 09:26 AM
SleepR1's Avatar
From what I've read the HMIC is just as effective as a large core SMIC...but as soon as you use a vented hood for either, SMIC or HMIC the cooling efficiency goes way up!
GKW
Sep 28, 2015 04:34 PM
