Throttle body mod, Worth it?
hey
i was wondering if the throttle body mod is worth it does it do any harm? does it give any horsepower and if so how much and where highend power?
oh yah this is on a fc series 5
thanks
thanks
Well i found that the throttle response was much better and possibly more power (I chucked a haltech on at the same time). It does take a bit of getting used to though, because the throttle isn't as stiff and it's too easy to over correct when opening and closing the throttle.
Stiff suspension doesn't help either. It's a bit hard to get a smooth throttle over bumps
It's still worth it though
https://www.rx7club.com/forum/showth...light=throttle
Read it all, theres a lot of controversy to get through.
How about disabling the first set of secondary plates so they stay open all the time and seeing what you think of it before removing the whole kit and kabootle????? I think this can be done on the turbo by removing that front dashpot that the black cam rides on. Thats on a series four turbo. On a series four n/a if you just remove the vac line to the diaphram the plates spring open fully all the time. Never done the throttle body mod myself, so the above could be claptrap. Just exercising the fingers.
Throttle Body Mod
Cons: Cold starts on cold days takes some pedaling to get warmed up.
Pros: Eliminate the fails-by-surprise coolant line.
Minor HP gain, Minor throttle response improvement.
Easier, faster access to upper engine stuff.
Trending Topics
CaptainKRM
14
Aug 26, 2015 09:52 PM
