Final Pictures and Status of NA Turbo Install
Old Mar 9, 2002 | 03:05 PM
Aaron Cake's Avatar
Engine, Not Motor
Talking LOTS of pictures of my NA turbo install
Moderators note:This thread is a blow-by-blow account of this install. It takes place over several months and things are presented in the order in which they took place. Consider this a prototype installation and as such is experimental.
A much better and more well documented version of this install is available here:
http://www.aaroncake.net/rx-7/naturbo.htm . While it is based around the same install and images, it's more organized and explained and has been updated with improvements and different ways of accomplishing certain aspects of this project.
Additionally, the car has gone on to receive far more upgrades. It's now running a GT4088R and making over 400HP at 13 PSI. This project thoroughly covered at http://www.aaroncake.net/rx-7/projecttina .
You asked, so here they are. 32 pictures, unedited, raw and uncensored. Keep small children and pets away, view at your own risk...
Turbo And Intercooler Before Cleaning/Modification
Intercooler showing rivits to be removed
More rivits to be removed
Intercooler - backing plate removed
Intercooler - back plate removed and cleaned
Old Mar 9, 2002 | 03:07 PM
Aaron Cake's Avatar
Engine, Not Motor
Turbo all cleaned up
Engine - Cold start, 6 ports, ACV, exhaust manifold removed
Throttle body with secondary butterflies removed (for throttle body mod)
Throttle body - secondaries removed, cold start removed
Same as above
Old Mar 9, 2002 | 03:09 PM
Aaron Cake's Avatar
Engine, Not Motor
NA exhaust manifold removed (air pump removed for clarity)
Rear of car in garage
Upper intake removed
Upper intake removed still
Oil Pan Removed
Old Mar 9, 2002 | 03:11 PM
Aaron Cake's Avatar
Engine, Not Motor
NA turbo adapter/Spacer
This adapter spaces the TII manifold out 2.5" so it clears the lower intake.
Old Mar 9, 2002 | 03:13 PM
Aaron Cake's Avatar
Engine, Not Motor
Oil cooler with bung installed for turbo oil supply
Oil pan with turbo oil drain pipe installed (don't laugh, I did that with an arc welder)
TII manifold with adapter on engine
Old Mar 9, 2002 | 03:16 PM
Aaron Cake's Avatar
Engine, Not Motor
Turbo installed
Showing how close the turbo is to lower intake
Turbo installed, various views
You will notice there is no wastegate on the turbo. It has been removed so the turbo can be test fitted. The wastegate seems to interfer with the inner fender. So, the fender will have to be....modified....with a hammer or saw to make things fit....Just didn't feel like doing that at the moment...
Old Mar 9, 2002 | 04:41 PM
amemiya's Avatar
let us know how it goes. I hope you have a fuel controler
InfiniIIIREX's Avatar
Wow, I am sure some NA guys will be jealous now Enjoy forced induction.
Old Mar 9, 2002 | 04:50 PM
rotaryracer1's Avatar
tell us how she does when you are finished
Old Mar 9, 2002 | 05:32 PM
VtekEater's Avatar
Talking Way to go man!!
Glad to see everything is coming along smoothly for you.
Guess those measurements worked out huh
Keep us updated
Old Mar 9, 2002 | 05:38 PM
vaughnc's Avatar
knowledge junkie
Once you're done, my convertible needs one of these
What ECU are you running anyway?
Old Mar 9, 2002 | 08:30 PM
Aaron Cake's Avatar
Engine, Not Motor
Yep, the measurements worked out. I will be making a VERY THIN blockoff plate for the ACV hole, and will probably end up having to tap my own holes to mount it. I just want to avoid that whole JB-weld situation. For what it's worth, the air pump still fits fine, so I will be able to run a cat. Also, I am thinking of extending the wastegate actuator arm intead of modifying the fender....I'll take a look at things tomorrow...
For the ECU, I am using the stock ECU w/TII injectors and an S-AFC. Probably some kind way to increase pressure...boost sensitive regulator? Don't know for sure, haven't got that far yet.
Old Mar 10, 2002 | 01:00 PM
Aaron Cake's Avatar
Engine, Not Motor
I just find it so funny that with all the NA -> turbo newbie questions, this topic gets so few views....
Old Mar 10, 2002 | 01:09 PM
jmseven's Avatar
Asset is Wealth
i'm view'in and awaiting results!
Old Mar 10, 2002 | 01:36 PM
vosko's Avatar
Just Call Me Terminator!
looks good a guy over here did that too
Old Mar 10, 2002 | 02:48 PM
defylogik's Avatar
me likey! GOOD JOB.. i was about to do that myself.. but sold the whip.
scott
Old Mar 10, 2002 | 11:33 PM
QC Motorsports
I was going to do that to my n/a but I have found that just buying the TII engine and moding that will be cheaper for me. good luck to you though, it looks good.
Old Mar 10, 2002 | 11:49 PM
rotorracing's Avatar
nice
Old Mar 15, 2002 | 03:32 PM
oh oh oh. my dream. stupid automatic convertible, my dog runs faster than it does.
How much did it cost you? How many parts, aside from the oil pan, did you have to fab?
Old Mar 15, 2002 | 05:57 PM
FDxc's Avatar
haha i know the pain.. but mine's not manual..
Old Mar 15, 2002 | 07:06 PM
Wankel7's Avatar
Haven't we ALL heard this
So what are you going to do for coolant passing through the turbo?
James
Old Mar 15, 2002 | 08:31 PM
ponykiller's Avatar
Wow, that looks good. You are right, it is funny with all the questions that this topic gets that there are so few views. Oh well, now we have a thread to make those newbies search for (if the search function ever starts working again).
Kris
Old Mar 16, 2002 | 02:01 AM
aaron cake when i did my turbo project on my n/a i modified the wastegate to fit in the space not the fender it is close but it will fit
Old Mar 16, 2002 | 02:48 AM
peejay's Avatar
Old [Sch|F]ool
is that turbo oil drain above the oil level in the pan?
Old Mar 16, 2002 | 10:18 AM
Silkworm's Avatar
Has been.. hangin' around
Wow. That's a hell of a lot of custom work. Looks good.
Heh, and I thought my garage was cluttered
PaulC
