Biggest FMIC you have seen in an FC?
Old Aug 19, 2007 | 11:44 PM
striker754's Avatar
What's the biggest FMIC that will fit in an FC? I don't mind cutting the bumper.
https://www.rx7club.com/attachment.p...3&d=1186131875 looks like that one is a 24x12x3
maybe fit a 31" wide or a 27"? I think a 27x12x3 might fit in there nicely
I still need to take my bumper off and see, but I thought I'd ask you guys first
Old Aug 20, 2007 | 12:03 AM
ZeroDrift's Avatar
I have a 24x12x3 FMIC setup, and the bumper was left intact.
edit: Oh yes, this is the largest FMIC I've seen on a FC... I'm sure there are some out there much larger though.
Old Aug 20, 2007 | 12:13 AM
walken's Avatar
Registered Loser
http://img3.freeimagehosting.net/ima...1111f0ad81.jpg <-- seen that in the classifieds and got a good laugh.
Old Aug 20, 2007 | 12:40 AM
FuStEr's Avatar
OMG ITS A TRIANGLE!
^ Wtf O_0
Old Aug 20, 2007 | 12:42 AM
slo's Avatar
slo
registered user
Do you still have a bumper core?
Have any pics with the bumper cover off?
Old Aug 20, 2007 | 01:12 AM
forced inducted fd dude's Avatar
brap brap brap
check thiss one out i believe its a npr fmic, im getting the npr <3
Old Aug 20, 2007 | 01:38 AM
ZeroDrift's Avatar
I dont have any pics with the bumper cover off. I have additional bracing in the front end to help keep things rigid up front since the bumper core has be removed.
Old Aug 20, 2007 | 02:15 AM
FrankV702's Avatar
The big NPR intercoolers are badass!! Ive always run one of those FMICs, Theyre big and cheap and the piping is soooo simple.
Old Aug 20, 2007 | 02:32 AM
brap brap brap
^^ not forget one very juicy fact here about the npr. ITS ******* TOUGH! btw how much did you get yours i found one for 3 bills
Old Aug 20, 2007 | 02:52 AM
Evil Aviator's Avatar
Rotorhead
Take the bumper off. You may not go about the installation the same as others, so your required dimensions may be different than what you read on the internet. I recommend making a cardboard mock-up before buying an intercooler, and make sure you plan for plumbing.
Mine is about 26x15.6x3.5" (20x15.6x3.5" core) and is rated for 1500hp @ 1.5psi pressure drop. It is mounted in front of the crossmember by the radiator rather than in the front fascia, so the hood latch had to be removed.
You can cut the front fascia, but you may want to consider that brake ducts that allow the car to stop and aerodymanics that keep the car on the road may be more important than 1-2% intercooler efficiency. It's not a good idea to cut the bumper due to safety reasons.
The really large intercoolers tend to be on cars with cut-up or removed bumpers, and/or blocked brake ducts. Not good.
Old Aug 20, 2007 | 03:08 AM
NZConvertible's Avatar
I'm a boost creep...
Are you actually making enough power to justify the "biggest FMIC that will fit in an FC?" Or is this just one of those look-at-me things...
Old Aug 20, 2007 | 03:34 AM
Omixeo's Avatar
'89 GTUs
Old Aug 20, 2007 | 03:40 AM
staticguitar313's Avatar
R.I.P. Icemark
^ i remember that ^_^
Old Aug 20, 2007 | 08:39 AM
striker754's Avatar
yes...enough power.
Old Aug 20, 2007 | 09:00 AM
kontakt's Avatar
is The Whoopieschnootz
^^ I'm not sure a 13b can generate enough power to justify needing the biggest intercooler that can fit in an FC. If so, I really wonder what the 20b guys do.
Old Aug 20, 2007 | 09:06 AM
striker754's Avatar
not a 13b. v8.
Old Aug 20, 2007 | 09:10 AM
Aaron Cake's Avatar
Engine, Not Motor
The next question is, what's the biggest FMIC mounted to an FC without totally destroying the inside of the bumper or cutting out supports?
Mine is about 24" x 14" x 3", mounted behind the bumper reinforcements just below the hood latch. I suspect you could go just a little wider (maybe an inch or so) but that's about the limit.
kontakt's Avatar
Well that makes sense then. What kinda snail(s) are you putting on what kinda block? It sounds like you're shooting for >1000hp if you're looking at a turbo V8.
Old Aug 20, 2007 | 04:46 PM
brap brap brap
8 turbos for each cylinder on my v8.. but then i woke up
Old Aug 20, 2007 | 07:08 PM
That Rx-7 kid's Avatar
car fanatic
hahaha...........im curious to see how this turbo v8 FC project will end up......
Old Aug 20, 2007 | 07:36 PM
kontakt's Avatar
I've seen that in an issue of Hot Rod. The only thing I remember is that the car was red and the plumbing looked like sex.
Old Aug 20, 2007 | 07:45 PM
Spectator's Avatar
3.5" is what I recommend and what I have. 4" you end up scrapping the intercooler just trying to place it...
And why the hell would someone want to remove th bumper?!?
Are you guys crazy? I mean, you're using the **** to race, and you're removing the bumper?
Did you know a guy named guitarjunkie28?
And what are you putting out? 700hp? Why do you need the biggest intercooler ever? Leave that **** intact and you might stay intact.
Old Aug 20, 2007 | 11:48 PM
TD07's Avatar
Old Aug 21, 2007 | 12:01 AM
imloggedin's Avatar
mmm radiators love blocked air
Old Aug 21, 2007 | 12:10 AM
DaBrkddy's Avatar
Smells like 2 stroke.
^Haha.. pwnt.^
Go with N/A... or be happy with what you have. :p
