electrical fab questions
Old Jul 15, 2007 | 04:43 PM
gear_grinder's Avatar
Don't hate my V8
hi,
i have a 87 TII and are soon to install a FMIC and are currently instaling a 16" electric fan, i was wondering where was the best place/easiest place to relocate the battery. Also where was the best place to connect an electric fan so that it comes on when the key is on. thanx again.
Old Jul 15, 2007 | 08:53 PM
arghx's Avatar
rotorhead
stock clutch fan is ugly but it flows the most air...
relocate the battery to the driver side storage bin.
look for the green plug near the driver's side shock tower for a switched +12V ignition source. You will need to wire in a relay though. Don't try to power the fan with a 20 gauge wire....
Old Jul 15, 2007 | 09:42 PM
Don't hate my V8
i was thinking of buying a battery box from napa cuz i'm gonna build a custom box were the storage pods are. but do u have more infor mation on the green wire? do i just hook the + of the battery? then i just need to ground the battery to the chasie and ground the ground up front too?
err green plug i mean
Old Jul 15, 2007 | 09:46 PM
Don't hate my V8
the "box" is going to be for a subwoofer setup, i want to free air (magnet in the air) a L5 or L7 12" subwoofer with the magnet just about inbetween the seats. i think that'll look sweet.
Old Jul 16, 2007 | 09:17 AM
Aaron Cake's Avatar
Engine, Not Motor
ReTED has a battery relocation How-To on his website:
http://fc3spro.com/TECH/HOWTO/BATTRELO/battrelo.html
He uses two breakers which I personally think is overkill, but if it makes you happy then go for it.
Old Jul 16, 2007 | 06:35 PM
Don't hate my V8
yeah thanx for that link, i think i'll beable to adaped it for my uses.
Old Jul 17, 2007 | 12:08 AM
NZConvertible's Avatar
I'm a boost creep...
Originally Posted by gear_grinder
...where was the best place to connect an electric fan so that it comes on when the key is on.
Don't be cheap and/or lazy. If you're going to do it, do it properly. The fan should be powered directly from the battery via a fuse and relay, with the relay controlled by a thermoswitch. There are no advantages to running an e-fan all the time, only disadvantages.
Old Jul 17, 2007 | 12:16 AM
1.3mazda's Avatar
HOT DOGS! 8======D
^thats true, you wire in the fan all the time and your alternator will barly keep up with the electric fan and the car itself, let alone a sound system on top of all that!
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
rotor_veux
Sep 3, 2015 07:10 PM
