Turbo II VS RX8 driveshaft splines
Looking to mate a turbo II driveshaft to a RX8 transmission. Are the splines on the tailshaft the same on both transmissions? Positioning on the RX8 trans will be the same distance as the TII trans.
I wouldnt bet on that, but its possible. As far as the spline goes. I dont know. Get the parts and find out. There are plkenty of driveshaft shops that can make you a driveshaft
the rx8 transmission is 3 inches shorter than the tII trans. That's not the problem. I'm moving everything back (motor/trans) 3 inches to line up the shifter in the correct spot. This would also line up the driveshaft to fit.
So I mated the TII driveshoft to the rx8 trans. Looks like it fits snug. I'm just looking for verification. I misplaced my calipers to check. I guess I could count the number of splines.
