battery relocation kits
Old Nov 29, 2006 | 09:22 PM
rotarydelight's Avatar
i'm going front mount and i need to relocate the battery. i am wondering which kit you guys use? how much trouble is it to install, and how much did you guys pay for the kit? thanks
Old Nov 29, 2006 | 09:42 PM
toplessFC3Sman's Avatar
kit? get some THICK wire (2 or 4 gage iirc, maybe less), battery terminal connectors, and just wire it back there. fab up a mount for it using the stock battery tray and strap it in
Old Nov 29, 2006 | 09:44 PM
takahashiRyosukeFC3S's Avatar
1 miracle from sainthood
made my own, it's not much trouble check the archives for a "how to". it didn't cost much, just wires, distribution blocks, and battery strap.
if your getting into the electronics of your car reground it if you haven't already.
TR
Old Nov 29, 2006 | 09:55 PM
876portturbo's Avatar
getcha brap on
I got a Summit battery tray for the rear bin, its was only twenty dollars and looks nice, it has wingnuts on both sides for holding the battery down, its chrome if you like that kind of thing. I used 4 gauge wire I think, my rear is gutted so it was easy to install into the passenger bin.
Old Nov 30, 2006 | 09:20 AM
Aaron Cake's Avatar
Engine, Not Motor
Funny how no one mentions using a fuse or breaker...
It is absolutely necessary that you put a fuse or beaker on the 12V feed from the battery as close as physically possible to the battery itself. With the way that most people run their 12V feed to the starter/engine bay, it is only a matter of time before the cable rubs through and shorts (not if....when). Without the protection of a breaker/fuse the battery will short directly to ground and cause the entire length of the cable to melt and catch fire...Thus burning down the car...
Personally I like to use breakers since a breaker can be easily reset and tripped at any time to cut power to the car. Fuses blow and must be replaced which sucks if you do something stupid at the side of the road in the middle of nowhere....
Old Nov 30, 2006 | 09:32 AM
dregg100's Avatar
what type of breaker should i buy? and can you just get them at like advanced?
Old Nov 30, 2006 | 09:37 AM
Aaron Cake's Avatar
Engine, Not Motor
You generally will not find them at an auto parts store. I buy Bussmann breakers, and generally use 150A for the battery. I get them from Waytek Wiring at http://www.waytekwiring.com . They're listed under Hi-Amp Breakers.
Old Nov 30, 2006 | 09:45 AM
Black91n/a's Avatar
I beleive that shoule be Waytek Wire. http://www.waytekwire.com/index.htm
That's where I got mine from, and I also ordered some really heavy duty shrink wrap at the same time. It's wonderful stuff, it helps protect against shorts, and it gives the joints some extra physical strength. Hell, it was strong enough to work on my dad's power steering hose with a hole in it. That held for several weeks while the new hose was on order.
http://www.fc3spro.com/TECH/HOWTO/BA.../battrelo.html
Old Nov 30, 2006 | 03:49 PM
classicauto's Avatar
Crash Auto?Fix Auto.
Also, if you ever plan on taking your car to the drags, you'll need a fulyl sealed battery box, or a dry cell battery (Odessey, and their pricey).
Im doing a custom aluminum box around my optima, all the other universal ones I looked at were too big for the storage bins...
Old Nov 30, 2006 | 04:19 PM
papiogxl's Avatar
What's the point??
They sell Bussman breakers at Advance Auto Parts.
I think I have enough room behind the front seat that I can mount the battery there.
Old Nov 30, 2006 | 05:08 PM
The Wankler's Avatar
FKITALL
Here are somepics of mine. But do not go with a 100amp breaker. Way to small. https://www.rx7club.com/showthread.p...light=progress
Old Nov 30, 2006 | 05:10 PM
PatrickT's Avatar
My batt is now there the spare tire used to be.
Didnt use any fuse, but a cable from BMW that is used for espacially such purpose.
I didnt know where to find a fuse that can handle such high currents.
If the car burns down , I will tape it for you
-Patrick
Old Dec 1, 2006 | 09:36 AM
Aaron Cake's Avatar
Engine, Not Motor
I always use 150A and have never had one trip...100A might be too small though. The Bussman breakers have a load curve that defines how long they take to trip at various overload levels...Something like 1000A and it trips instantly, 700A for half a second, 500A for 10 seconds, etc...
Have you ever tripped the 100A unit?
Also, make sure to add your thread to my projects sticky!
Old Dec 1, 2006 | 09:40 AM
RETed's Avatar
I would use at least a 150A.
I think the 100A is too small.
I used to trip a 150A guaranteed when trying to crank 3 - 5 times trying to unflood (Haltech install).
Upon normal use, the 150A should be okay.
But I'd worry with a 100A.
I think the stock starter is rated at 90A peak current draw?
-Ted
Old Aug 8, 2007 | 11:38 AM
danegerous's Avatar
it go down in the dm
Strong bump but is there no hazard of battery fumes or anything? I thought you needed to have the battery ventilated or sealed and such
Old Aug 8, 2007 | 02:31 PM
papiogxl's Avatar
What's the point??
That issue was already addressed by classicauto in post #9
Old Aug 8, 2007 | 05:13 PM
ericgrau's Avatar
Clean.
Ya I was gonna say, "There are kits for this?" Have you seen all the people who don't even have their stock battery boxes and hold-downs anymore? It's just sitting there. Not that I advocate such mounting, I'm just saying it doesn't take much to hold the battery in place. Even the stock setup isn't too fancy. Use your imagination.
Ideally you'd use a breaker rated for the same amperage as the main fuse (80A) and get a slow-blow breaker. But that's the ideal world. Unless you can find such a thing and you're sure you have the right part (how slow is "slow"?), you're probably better off trying what people like Aaroncake have done in the real world. On the flipside you might be unlucky and end up with a 150A fuse that trips too fast. I mean, does the starter pull more than that?
Old Aug 9, 2007 | 10:06 AM
danegerous's Avatar
I didn't mean just to mean race sanctions I meant more or less for safety in general. Thanks for the help though.
Old Aug 9, 2007 | 10:40 AM
evl mnky's Avatar
Rototiller
question. If you relocated the battery would you ground the (-) terminal to the chasis back there and then also ground the (-) that originaly went to the battery to the chasis under the hood?
Old Aug 9, 2007 | 10:52 AM
sure, why not? its not like its gonna hurt anything
Old Aug 9, 2007 | 11:13 AM
RETed's Avatar
That's the preferred method.
-Ted
Old Aug 9, 2007 | 07:27 PM
stylEmon's Avatar
FC since 99
i used the moroso kit. Its not too expensive and is considered a sealed box. Although, I've never have it fully closed since I got it. Typically, you wont ever be exposed to the 'vapors' from the battery. Unless you car is completely air tight, and you sit in it for a couple hours with no air...
But i installed the vent tube anyway.
https://www.rx7club.com/showthread.p...=progress+on+7
It was really easy to install. Its pretty much fits in the passenger rear bin, but you'll have to modify the lid a little to make it look seamless.
Old Aug 9, 2007 | 08:50 PM
psychotic7's Avatar
i drilled holes at the bottom of the driver's side compartment and ran my wires through there, of course that is what is use to house my optima red top. any stereo shop has the wiring you need, they sell awesome quality wire for amps which works well for a battery relocation project. the shop here sells up to 0 gauge at like a buck a foot.
Old Aug 10, 2007 | 12:18 AM
freemanrx7's Avatar
^Hold On
Try this
K4B00SS
1st Gen General Discussion
Sep 3, 2015 08:13 PM
