Racing Beat Oil filter sender adaptor installed <pics>
Old Sep 26, 2006 | 11:07 AM
Section8's Avatar
My CD player died, so i decided to yank the stereo and put gauges in there. I decided on the racing beat adaptor to mount the senders for my oil temp and pressure gauges. Piece is very well built, installed very easily. The only downside is that i think i will now have to remove the elbow to change the filter. I haven't tried removing/installing the filter with the elbow in place yet.
Old Sep 26, 2006 | 06:08 PM
KITT's Avatar
looks good but i hope you dont have to take the elbow off to change the filter
Old Sep 26, 2006 | 06:18 PM
rynberg's Avatar
Nope, but you will have to pull the TPS Harness and push up the fast idle cam out of the way. It's a PITA.
Old Sep 26, 2006 | 06:33 PM
adam c's Avatar
Cheap Bastard
I would have liked to see pics without the oil filter installed
Old Sep 26, 2006 | 06:41 PM
silverTRD's Avatar
Time or Money, Pick one
does the respeed mount require removal of the TPS harness since it replaces the stock pedestal?
Old Sep 26, 2006 | 06:58 PM
Mahjik's Avatar
Mr. Links
No, its the same height as the stock pedestal.
Old Sep 26, 2006 | 08:13 PM
Section8's Avatar
that's what i ordered originally actually, but in my zeal to get it, i didn't notice that it would need a bung welded for the oil line, and i didn't feel like dealing with that so i sold it to an FC track buddy.
This works pretty well, however now i'm having problems with the oil pressure gauge, not sure if it is the sender or the connection. It worked on first fire up, then died. Hasn't worked since.
Old Sep 26, 2006 | 08:15 PM
Mahjik's Avatar
Mr. Links
What pedestal are you referring to? I have the Respeed one and did no welding what so ever.
Old Sep 26, 2006 | 08:25 PM
Section8's Avatar
sorry, i spoke too quickly. it was one from speedmachineperformance. I guess it was an FC pedestal and I was just being an idiot and not paying attention when i ordered it.
Old Sep 26, 2006 | 11:21 PM
silverTRD's Avatar
Mahjik,
did you order the pedestal with the -10 line for an oil cooler setup?
at any rate how is the quality of the respeed pedestal? i have heard one complaint in the past. thanks
Old Sep 26, 2006 | 11:28 PM
Mahjik's Avatar
Mr. Links
Mahjik,
Respeed as long since fixed their issues with the pedestal. I ordered mine before the -10 line was available, however I probably still would have stuck with the banjo fitting. A friend of mine who is an engineer said he preferred the banjo fitting instead of the AN fitting for a few various reasons (as I could have used and adapter and replaced the banjo without the direct -10 fitting on the pedestal).
Old Jun 20, 2007 | 03:46 PM
thetech's Avatar
****** of disaster
I know this is slightly from the dead, but does I wasn't aware that the RB adapter fit on the FD pedestal?
This is for this one, right? http://racingbeat.com/resultset.asp?PartNumber=11803
Old Jun 20, 2007 | 06:21 PM
preludesh2000's Avatar
i installed the respeed pedestal a month or so ago....great piece
anyone wants to see installed pics of the respeed pedestal with out the filter, i started a thread little while back...
search for something like ... oil pedestal ... or respeed oil pedestal
brad
