Fog lights
Old Aug 24, 2006 | 11:51 AM
nopistonsPWR's Avatar
BRAP BRAP BRAP
Fog lights
i have an 89 na gtu and it doesnt come stock with a fog lihgt. so i got the fog light and the switch for it and some reason, it wouldn't work. i also check the fuse and the bulbs. doesn't look like anything was wrong with that. so any suggestion on what should i do to check it?
Old Aug 24, 2006 | 01:35 PM
Icemark's Avatar
are the bulbs good???
and your bump was deleted. Bumps are forbidden here in the 2nd gen technical section.
And a bump after only a half hour kinda makes you look like a spoiled child, that thinks your question is more important than anyone elses.
Old Aug 24, 2006 | 02:52 PM
zionfarm's Avatar
Military Rotary Guru!!!
question
what is a Bump
Old Aug 24, 2006 | 03:07 PM
contactsysadm's Avatar
Shoulder Devil
Is the switch good? Maybe the contacts need to be cleaned?
Bump=
http://www.urbandictionary.com/define.php?term=bump
Old Aug 24, 2006 | 05:58 PM
Enthu's Avatar
Still has an RX7.
Probably bulbs, but I had 2 wires that were corroded (they had all that blue dusty crap around them) and had been severed by corrosion. The other fog light I had trouble with once was a bulb out.
You should grab power tester and see if there is voltage at the plug on the switch half of it. If not, then you at least know where to begin.
Old Aug 24, 2006 | 06:54 PM
Dak's Avatar
Dak
Information Regurgitator
Along with not having the fog lights or the switch, my GTUs was also missing the relay. The switch controls the relay which applies the power to the lights. There were three relays on my car to start with.They are located just behind where the nose and hood meet. If there are 4 there make sure they're all plugged in. If only three that may be your problem. Also automatics have a relay for the aux. fan but I think they also have fog lights so they would have 5 as do the Turbo II as it also has the aux. fan. I don't know if this applies to series 4 cars but since yours is an '89 it should be tha same.
Old Aug 24, 2006 | 09:35 PM
BRAP BRAP BRAP
yeah ima bout to check the voltage of the wire and see if it got some pwer running through. thanks alot ima keep it in mind
Old Sep 6, 2006 | 03:45 AM
wiL87's Avatar
noob here. sorry to bring this back up again but I have a 91 coupe that didn't come with foglights. I also plugged everything in (foglights and switch) and still haven't really put in time to making it work. I found this thread
https://www.rx7club.com/showthread.p...hlight=OEM+Fog
where they talked about putting in a relay.
If you just take the relay off of another rx7 with the foglights does it plug right up? or is that not how the relay works? If it does just plug up will it work after and is there a harness that goes into the relay?
Old Sep 6, 2006 | 04:22 AM
wiL87's Avatar
nvm i think i found a post that answered my question ^
Old Sep 7, 2006 | 06:17 PM
Dak's Avatar
Dak
I didn't read the post above but a brief scan through. I used the factory relay out of the car I got my fog lights from. The plug is there that goes to the relay they just left the relay out on non fog light equipped cars.
Old Sep 7, 2006 | 08:08 PM
daten's Avatar
When I put factory fog lights in my GTU, I ran into the same problem, searched the forums, found out I was missing a relay, pulled the relay off the car I got the fog lights from, put it in the GTU, plugged it into the matching plug on already on the harness and it all worked fine.
Also, they only work when your headlights are on.
Old Dec 23, 2006 | 10:56 AM
zionfarm's Avatar
Is the plug green that goes to the fog light.
Old Dec 23, 2006 | 01:39 PM
Dak's Avatar
Dak
If you mean the plug that plugs into the relay. Yes. At least it is on my '89.
Old Dec 23, 2006 | 01:49 PM
micah's Avatar
Winter sucks
http://www.rotorwiki.com/index.php/S...Fog_Light_Swap
Edit: The write-up isn't complete as I'm still waiting for the fog-lights themselves to get through the holiday rush... UPS = teh suck. But the rest should be accurate.
Old Dec 23, 2006 | 05:56 PM
zionfarm's Avatar
Thanks alot micaheli i found the green relay plug in just waiting on the fog lighs to come in from ebay. In the pic r those the metal brackets they come with
http://cgi.ebay.com/ebaymotors/ws/eB...3825447&rd=1,1
Old Dec 23, 2006 | 06:44 PM
micah's Avatar
Winter sucks
I'm waiting for my set to come in from ebay as well. And yes.. You are getting the following:
*Fog Lights
*Fog light brackets
*Wiring Pigtails
You will not however be getting the fog light surrounds/ducting which, IMO adds to the clean factory look of the fog lights...
Here's an example (the auction I won. hehe)
http://cgi.ebay.com/ebaymotors/ws/eB...m=220061344671
Old Dec 23, 2006 | 06:45 PM
micah's Avatar
Winter sucks
Oh, also, did you get the relay for the green connector? I might have a spare if you need it.
Old Dec 23, 2006 | 06:55 PM
zionfarm's Avatar
My FC came with the surround/ducting, Yes i got the relays allready.
Thx micaheli
Old Dec 23, 2006 | 07:05 PM
micah's Avatar
Winter sucks
Oh.. right on then... Didn't know if you were equipping a base model.
Old Dec 23, 2006 | 09:10 PM
zionfarm's Avatar
no biggy i have a GXL, it came with the fog switch allready and the ducts but i got it with no fog lights. My guess is it wuz a dealership add on. Or previous owner took them off.
Old Dec 23, 2006 | 09:43 PM
micah's Avatar
Winter sucks
Previous owner probably took them out to replace the bulbs, or blew a bulb and couldn't afford to replace them. so he removed the lights...
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
