6 speed
Trending Topics
Originally Posted by rotarygod
There are far more useless mods that get done by most of the members of this forum on a daily basis than swapping to a 6 speed tranny. I wouldn't consider that useless.
Originally Posted by mdq-fc3s
why would that be useless?, the 6 speed gives better gearing than a 5 speed which would lessen the rpm drops when shifting.
Ever think they geared the Rx7 the way they did on purpose? Ever think that maybe their engineering was better suited for the car than a transmission from another car?
Just a thought...
Just a thought...
I have a sixspeed in my FC... but its attached to a 5.7L powerplant
you could get the RX8 trans to work,
but if you want better acceleration from shorter gearing you can get a mazdaspeed gear set
or even just changing the rear end gear from the stock 4.1 to something shorter (numerically higher) like closer to 5.0 would make your car FREAKIN RIP!!!!!!
Just a thought...
Just a thought...
actually the s15 6 speed transmission center section is the same as the rx8. Its alot cheaper than the rx8 6 speed. All you need is a bell housing from the rx8 ( $600 ) and the tail shaft ( $125 ). S15 transmissions are about $800- $1500.
Thanks Robert
Thanks Robert
If we're talking about an NA here, there's been lots of good posts from before.
Do a search.
If we're talking turbo here, don't even bring up the RX-8 trans, cause it's going to explode in a week.
-Ted
Best engineering on a trans goes to:
http://www.xtremerotaries.com/main2/guru/gearbox.htm
That is only $8900 australian dollars so like $14.85 USD
Those links will take you to race applications for the transmissions. Dog boxes are great for racing but I hardly believe they would make a nice streetable car. I'd stick with the stock tranny and change out the ring and pinion to a 4.8 like someone said earlier.
Originally Posted by catchafox
so what is the strongest and best gear box in a turbo fc?
Classic.Really though, it's ~6,646.64.
I have an s2000 trans in my car; It lines up with the oem shifter hole an everything. The problem is theres an s2000 engine in my car too. But, if you could somehow mount a rotary to it and you would be set!
Originally Posted by andrewb70
I thought this thread was about 6-speeds?
-Ted
