water temp sensor location??
Old Apr 2, 2006 | 07:55 PM
cdaleracer669's Avatar
yes,thats me \/
i am looking at aftermarket gauges. i was looking at one that would use an adapter that you put inline with a radiator hose. my question is, where would i put it becuase if its low on coolant it wont be pumping coolant through the system and wont show its overheating when it really is. would the heater-firewall hose work?? plz answer ASAP i was going to order one tonight
Old Apr 2, 2006 | 08:05 PM
Funkspectrum's Avatar
Under the intake manifold, there's a coolant hose that comes out of the rear iron, routes through the throttle body, and goes back into the water pump housing.
I'd use the line coming out of the rear iron. Just patch a 'T' fitting into it with a hose and the sender....
Old Apr 2, 2006 | 08:18 PM
Aaron Cake's Avatar
Engine, Not Motor
I searched for "temperature sender location":
https://www.rx7club.com/forum/showth...ender+location
And searched for "temperature sensor location":
https://www.rx7club.com/forum/showth...ensor+location
Old Apr 5, 2006 | 05:19 PM
yes,thats me \/
i made an adapter to go on the heater hose, so it is about 3-4 inches away from the stock sending unit. here are some pics. i snapped a pic of my car while working on it also, a lil dirty tho
Attached Thumbnails water temp sensor location??-img_2261.jpg   water temp sensor location??-img_2259.jpg   water temp sensor location??-img_2262.jpg   water temp sensor location??-img_2264.jpg   water temp sensor location??-img_2263.jpg
Old Apr 5, 2006 | 05:22 PM
yes,thats me \/
oh, and if anyone decides to do this with theirs you will need someway to ground it. i ran a wire from a good solid bolt in the block to the sending unit. works great
Old Apr 6, 2006 | 06:11 AM
NZConvertible's Avatar
I'm a boost creep...
Whenever the heater is off there'll be no flow in that hose. This will dramatically slow the response of the gauge. Basically unless the heater's on the guage will be inaccurate. Bad location.
Snoopy FD
Dec 8, 2015 01:45 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
