What's A Good Injector Cleaner??
Old 11-06-05, 05:31 PM
Gallardo's Eggroll Shop's Avatar
Yeah I was just wondering what brand is good when it comes to cleaning the injectors because on start up the rpms go to about 1k then it drops down to 0 and that's wen the car just dies. I'm thinking that not enough fuel is going in, and I want to clean my injectors. Thanks for any help.
Old 11-06-05, 06:07 PM
MazdaTed's Avatar
Cheveron Techron, or lucas fuel treatment. Be sure to follow instructions, like pour into neary empty tank, and pour fuel on top.
Old 11-06-05, 06:18 PM
That's JDM tight, yo
311unity13B's Avatar
i've always wondered if it was ok to put injector cleaner in our cars, since our engines are alot pickier than piston engine are on what products u put into them
Old 11-06-05, 06:23 PM
rodney87's Avatar
I've put seafoam into my car several times, gas tank for fuel and vacume line for everything else. It hasn't hurt anything so far and it works miricles, follow the directions for cleaning out carbon and the car smokes like a badass for a few min when your done. Although I cant emagine its helping my already old cloged cats...
Old 11-06-05, 06:24 PM
MazdaTed's Avatar
I dont see why it would hurt. we pour ATF into our engines, piston heads wont do that. Maybe the Wankel is more resistant to that stuff... maybe.
Old 11-06-05, 06:33 PM
REnaissance_Sle7in's Avatar
Where can you buy seafoam? This is the first I've heard of it, and I would like to try it out...unless I hear that it is bad for the rotary
Old 11-06-05, 07:27 PM
1noblerider's Avatar
amsoil would have somthing for you. find a amsoil dealer and contact the company. tell them what you have. they are a top notch company. Also ask racing beat. they will know
Old 11-06-05, 07:54 PM
MazdaTed's Avatar
It is sold at my autozone, nobody buys it so I wouldnt assume it is good.
Old 11-06-05, 07:55 PM
FLY NAVY
jl1rx7's Avatar
i used redline injector cleaner for years works great can get it at pep boys and i think advance, so fairly easy to get
Old 11-06-05, 08:09 PM
Opinions are like........
deadRX7Conv's Avatar
There are plenty of good FI cleaners.
Gumout Regane
BG44k
B12 Chemtool
Seafoam
Marvel Mystery
Lucas
Amsoil
Redline
Schaeffers
3m
VentilSauber
Neutra
SoyUltra
I've used all of the above in the past and have not had ANY fueling problems in any of my cars, and cars that I service. Just read the directions, and add the bottle while at the gas station during a complete fillup. Also, if the fuel filter has 30k or more miles, REPLACE IT. I am also a firm believer that a bottle at an interval(like every 3-4 months or when you change your oil) can prevent certain problems from beginning.
Old 11-06-05, 11:33 PM
rodney87's Avatar
I got mine at checkers
Old 11-06-05, 11:43 PM
Dancing w/ teh devil...
Mason Rx7's Avatar
I use MMO (Marvel Mystery Oil).
I have heard lots of good stuff on here about Seafoam.
Old 11-07-05, 12:50 AM
Syonyk's Avatar
Subaru guys swear by seafoam. Cleans up the tapping lash adjusters beautifully.
If your injectors are really bad, Cruzin Performance & RC Engineering are some companies that come to mind that do professional, out-of-car injector cleaning/blueprinting. You may also be able to find a local shop.
HOWEVER, I don't think your problem is clogged injectors. And if it is clogged injectors, they're so bad that running some stuff through the tank won't help a bit. If it fires up and immediately dies, start your troubleshooting with fuel pressure & the airflow meter. If the fuel lines are hooked up backwards, the engine will start & die like that, and if the airflow meter is not hooked up or has gone bad, the engine will start & die. A totally clogged fuel filter would also cause this, but it would be very difficult to get a filter clogged that badly.
-=Russ=-
Old 11-07-05, 07:59 AM
HAILERS
HAILERS's Avatar
The MAZDA corp recommends the following:
Subject:
FUEL INJECTOR CLEANER
DESCRIPTION
To improve fuel injection performance, Mazda has tested and approved a highly effective FUEL INJECTOR CLEANER. The kit and cleaner is recommended for all Mazda fuel injection systems. Mazda's Fuel Injector Cleaner uses a chemical "reducing agent" rather than the common solvent used in the typical aftermarket cleaners. As a result, in tests against aftermarket competitors, Mazda's cleaner outperformed all others and was the only one to restore the fuel injector's flow rate to the original factory specifications.
Dirty fuel injectors are an increasing common problem. Many cases are due to gasoline deposits such as gum, resin and sulfur. These deposits can cause stalling, difficult starting, rough idle and diminished power.
The part number is 0000 77 2019
Never used it my self. The above was from a Trouble Shooting Bulletin.
Old 11-07-05, 08:02 AM
bradenscreed's Avatar
Exclamation
see, when a company proclaims there's is best by tests, that doesnt sway me, when an independant company w/ no bias does the same tests, thats what i go by. anyone care to run a couple tests?!
Old 11-07-05, 08:14 AM
is The Whoopieschnootz
kontakt's Avatar
It figures that there's a whole thread full of "this cleaner works well" "does it work on rotaries?" "lots of people swear by this cleaner, even on this forum" "I'll use it when I find out it's good for rotaries" "There's this cleaner that MAZDA RECOMMENDS" "I don't believe in recommendations."
Old 11-07-05, 08:30 AM
i dont quite understand what youre trying to say
Old 11-07-05, 10:48 AM
Engine, Not Motor
Aaron Cake's Avatar
Remove them, and send them to an injection shop to be cleaned. Generally costs about $20 per injector. You will NEVER get them clean with chemical cleaners added to the fuel.
Old 11-07-05, 11:18 AM
HAILERS
HAILERS's Avatar
So. When Mazda recommends a given weight motor oil or transmission oil, you disregard the recommendation and try multiple weights of oil. Maybe even water in lieu of oil just to see if it works better?
Old 11-07-05, 12:02 PM
kontakt's Avatar
Aparantly noone knew what I was trying to say. All I said was exactly what the thread had already stated. A bunch of people kept questioning if the stuff being listed was safe for our motors. As soon as someone mentioned something Mazda recommended, someone had to chime in and say that they don't believe that it's actually the best because the company is just promoting itself. I'm saying that there's no 3rd party proof (though there may be 3rd party recommendations) that ANY of these is better than the next, but that one's recommended by Mazda, so why not use it? I guess I was just making a useless post hating on useless posts.
Edit: No, seriously... Hailers... how did you get from my first post that I was putting down Mazda's recommendation?
Old 11-07-05, 05:05 PM
HAILERS
HAILERS's Avatar
Probably these words: *******I don't believe in recommendations********
Old 11-07-05, 06:24 PM
2turbos
Joe Geiman's Avatar
Use Chevron Techron or Valvoline injector cleaner. There are others that work well. The ones mentioned here are good products that work.
Follow the instructions.
An in the tank cleaner will get the injectors about 75-80% clean if extermely dirty. An on the rail type system will get about 85-90% of the dirt.
The best is a complete clean off the car with a flow check and match.
Joe Geiman
Gasoline Alley Fuel Injection
Linder Technical Service
www.lindertech.com
FD7KiD
15
02-26-21 10:12 PM
FD7KiD
08-17-15 11:50 PM
Quick Reply: What's A Good Injector Cleaner??
