My horns SUCK
Old Aug 13, 2004 | 04:29 PM
tookwik's Avatar
VIP - Very Irish Person
My horns SUCK
I got to thinking about this a lot last night when I had a couple *** holes pull out in front of me. Why is it that the horns on our FD's royaly suck. I mean... I have had two 3rd gens that have done this so I know it couldn't just be my luck. Its to the point where I can tap the brakes while holding down the horn and it will SIGNIFICANTLY change pitches when the lights come on. Also, since we have 2 different horns each at a different pitches I most often only hear one of them. Every know and then both will come on. They will also increase strength with the rpms... they sound perfectly normal when going anything above 45mph. Anybody else suffer from this? and does anybody else have a solution?
Old Aug 13, 2004 | 05:00 PM
Elegant Black Monster's Avatar
She's on Sale!
Check your grounds.
Old Aug 13, 2004 | 05:02 PM
DaleClark's Avatar
RX-7 Bad Ass
Time to upgrade the horns . I had air horns in my '88 T2 - sounds just like horns on a Ferrari or something. Biggest advantage was they were VERY loud and got attention VERY fast. You get some quick responses when you lean on 'em!
You can get cheap Fiamm ones at Pep Boys for like $20-30 or so.
Dale
Old Aug 13, 2004 | 05:08 PM
adam c's Avatar
Cheap Bastard
The horns (if you have 2) on the FD are really bad. My 94 PEP had only one horn, and it was pathetic. I went to Kragens and bought a 108 decibel Magnum Blaster horn. It was around $16, and works very well. I even like the sound
Old Aug 13, 2004 | 05:13 PM
silver93's Avatar
got a replacement from napa for like $15 or $20 - SOOO much better. you can actually hear it -
Old Aug 13, 2004 | 05:59 PM
2a+RoN's Avatar
I totally agree about the horns, and all my friends make fun of how ***** they sound. Yesterday, some older lady totally jacked me, I honked and she freakin stuck her tounge out at me. I wanna horn that will really let these jack holes have it!
Old Aug 13, 2004 | 06:33 PM
tookwik's Avatar
I was thinking about the HELLA horns that I've seen sold at a few places. They're like $100 though. I want something that will make 'em jump.
Old Aug 13, 2004 | 06:36 PM
yodaddy's Avatar
go still one off a train
Old Aug 13, 2004 | 06:52 PM
tookwik's Avatar
I would love to go "still" one because "stealing" might be illegal
Old Aug 13, 2004 | 07:35 PM
yodaddy's Avatar
that's exactly why i spelled it that way, good job, you get a gold star.
Old Aug 13, 2004 | 07:55 PM
RoTorYRooKiE's Avatar
Padawan
damn, thought that the horn problem was only me...don't know anyone else that owns an FD...so yeah, looks like a pep boys replacement is looking good.
Old Aug 13, 2004 | 08:32 PM
tookwik's Avatar
SWEEEEET!
Would it be better to just run two completely new lines to two new horns? Actually, i can't imagine running a line back to the steering wheel... can somebody find out where it would be best to splice into for some new ones. It seems obvious that it shouldn't be done at the stock horns.
Old Aug 13, 2004 | 08:36 PM
InsaneGideon's Avatar
Still on 1st engine
Just splice at the horn relay. You shouldn't have to screw with the steering wheel.
While you're at it, you might consider running better grounds or maybe a dedicated + feed, especially if you're upgrading.
Old Aug 13, 2004 | 08:40 PM
tookwik's Avatar
so there is a dedicated horn relay? If you don't mind me asking, do you know where it is? I can look it up later if you don't.
Old Aug 13, 2004 | 08:49 PM
Still on 1st engine
Yes... it's SOMEWHERE
I think it's in that relaybox near the stock intake.
I'm far away from my manuals right now.
Old Aug 13, 2004 | 09:55 PM
yes, its the long relax box near the stock intake and if you have that stock cover on it, its under that
Old Aug 13, 2004 | 10:29 PM
DaleClark's Avatar
RX-7 Bad Ass
Actually, most horns wire straight to battery or switched power with a relay - the stock horn lead just switches the relay on.
I know air horns need a good supply of current. They actually have a small air compressor that blows air through the horns. Air horns are CRAZY loud - I really dig the sound!
Dale
Old Aug 14, 2004 | 12:41 AM
prew's Avatar
i use the horn alot. i like to honk at people on the side of the road, especially girls that look good. but like some of you, one of my horns stopped workin awhile back and now it sound so weak. im embarrased to even use it unless its an emergency. and then it probably wouldnt be heard. definately need to upgrade.
steve
FC3S Timmy
16
Oct 3, 2015 01:08 AM
