Electron Manipulation
Old Aug 10, 2004 | 11:17 AM
dubulup's Avatar
development
Lightbulb Electron Manipulation
In the beginning...
Attached Thumbnails Electron Manipulation-ecu.jpg   Electron Manipulation-pict0086.jpg   Electron Manipulation-pict0078.jpg   Electron Manipulation-backshell.jpg   Electron Manipulation-start.jpg
Old Aug 10, 2004 | 11:20 AM
dubulup's Avatar
development
Attached Thumbnails Electron Manipulation-bend.jpg   Electron Manipulation-finish.jpg   Electron Manipulation-pict0054.jpg   Electron Manipulation-pict0070.jpg   Electron Manipulation-pict0072.jpg
Old Aug 10, 2004 | 11:26 AM
dubulup's Avatar
development
The End.
Attached Thumbnails Electron Manipulation-plug.jpg   Electron Manipulation-pict0103.jpg   Electron Manipulation-pict0104.jpg   Electron Manipulation-harness5.jpg   Electron Manipulation-harness6.jpg
Old Aug 10, 2004 | 11:50 AM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Very NICE!!! man, you are the man when it comes to electrical stuff.. I remember you with that switch you put in.. So, when do you expect all to be done?? Looks good so far!!
Old Aug 10, 2004 | 12:55 PM
Fatman0203's Avatar
I guess thats the new wireharness you made?
Old Aug 10, 2004 | 02:53 PM
dubulup's Avatar
development
Thanks PHIL! I guess it's an occupational hazard
hopefully end of this month.
Old Aug 10, 2004 | 02:55 PM
dubulup's Avatar
development
Yes, with the Haltech kit, you get a flying lead harness to play with.
Old Aug 10, 2004 | 03:02 PM
dubulup's Avatar
development
PHIL is talking about converting the blank console switch to a momentary toggle [IC sprayer]...very clean and 007ish.
Attached Thumbnails Electron Manipulation-cust_sw3.jpg   Electron Manipulation-cust_sw.jpg   Electron Manipulation-pict0033.jpg   Electron Manipulation-pict0008.jpg   Electron Manipulation-pict0434.jpg
Old Aug 10, 2004 | 03:08 PM
KaiFD3S's Avatar
SINFUL7
Daym, I could never do that, that looks so confusing....
great job...
Old Aug 10, 2004 | 03:10 PM
dubulup's Avatar
development
great job...
you can do anything if you put your mind to it...that's what Doctor Emit Brown use to tell me.
Old Aug 10, 2004 | 03:13 PM
KaiFD3S's Avatar
SINFUL7
That is true, maybe if a time came that I had to do it myself, I would be able to do it...
Old Aug 10, 2004 | 03:34 PM
dubulup's Avatar
development
Time is a must...I'm no genius (<---if that is even spelled right, haha)
Old Aug 10, 2004 | 03:51 PM
Herblenny's Avatar
What is this?? Your new engines??
Old Aug 10, 2004 | 04:02 PM
dubulup's Avatar
development
just seeing who is sleeping in class
Old Aug 10, 2004 | 04:06 PM
Fatman0203's Avatar
Have you tested the harness? It would suck if you put it all back together and you made a mistake somewhere.
Old Aug 10, 2004 | 04:16 PM
dubulup's Avatar
development
yes, I did a continuity check before final wrap. I made diagrams with reference designater #'s from ECU pin # -> Receptacle socket #...Plug pin #'s to senors. It was definitely not something thrown together in hopes that it would work. Here is a pic of my "tool/supply/diagram" box for the project.
Layer 1 ---------------Layer 2 ------------------Layer3
Attached Thumbnails Electron Manipulation-pict0056.jpg   Electron Manipulation-pict0057.jpg   Electron Manipulation-pict0058.jpg
Old Aug 10, 2004 | 04:30 PM
XSTransAm's Avatar
Ee / Cpe
nice job, have you played with the e6x much?
Old Aug 10, 2004 | 06:00 PM
dubulup's Avatar
development
THANKS!
Not yet, but I plan to tomorrow. I've read thru the manual many many times in it's entirety. I'm excited about what it's capable of!
Old Aug 10, 2004 | 06:49 PM
spurvo's Avatar
don't race, don't need to
I officially bow to you Dubs! Absolutely SUPER job on the harness. You actualized what I'd been swishing around in this ugly thing I call a brain.
Aren't all those pins fun?
Ho hum, 4 rotor FD <yawn>... Don't you know the 3 rotor cosmo is the shiznit? I'm gonna put THREE of them in MY FD (when I.. ummm.. get out of high school and stuff...)
Donning flamesuit over here!
Again, really nice job, and then some!!
Old Aug 11, 2004 | 01:12 AM
MrRx's Avatar
Rotary on a budget
So you have 3 26b motor sitting there, how much did it cost you to build those?
And jesus thats gonna be sweet when you get it all done
Old Aug 11, 2004 | 01:41 AM
ejmack1's Avatar
Lawn Ornament
question:
Could that wiring harness be manipulated to be used with the PFC?
Is that the wiring harness that comes with the Haltech?
Part numbers on the connector from the engine side of the harness to the ECU side?
Old Aug 11, 2004 | 07:01 AM
dubulup's Avatar
development
Thanks buddy! The pins weren't all that bad, I had a really neat crimp tool to use.
They are not mine, BTW. Just thought I'd throw in some eyecandy.
Originally Posted by ejmack1
question:
(1) Could that wiring harness be manipulated to be used with the PFC?
(2) Is that the wiring harness that comes with the Haltech?
(3) Part numbers on the connector from the engine side of the harness to the ECU side?
(1) Yes, you'd have to cut all the wires and make the connector
(2) I wouldn't say a "harness" comes with the Haltech, it's a bunch of wires connected to the ECU plug. I turned the wires into that harness.
(3) see attach.
File Type: pdf
File Type: pdf
Old Aug 11, 2004 | 03:18 PM
ejmack1's Avatar
Lawn Ornament
(3) see attach.
I have already butchered my harness to only contain the "needed" wires for my setup... I ran all new wiring, and used existing 10 yr old connectors... im looking to add a quick disconnect, and put some new wiring meant for engine use....
Old Aug 11, 2004 | 04:15 PM
dubulup's Avatar
development
^ cool, I remember reading your thread.
I used the 37 pin connector, strictly for "room to grow".
I simplified the harness as much as possible running it thru the connector...I'll go from memory
1 - 12V source
1 - GND
1 - 5V source
1 - AIT
1 - Coolant
4 - Injectors
4 - CAS
1 - O2
1 - sheild termination (for CAS & O2)
1 - ISC
so, it's really not that many wires that "need" to pass thru. (probably missing one or two?!?!)
I didn't pass any of the tranny or ignition thru...they stay in the car when engine is removed. I didn't pass any ECU or Fuel Pump PWR wires thru...all that is in the cabin.
Old Aug 11, 2004 | 06:21 PM
ejmack1's Avatar
Lawn Ornament
awesome man, care to share any of your diagrams? especially when wiring in the dash gauges and stuff?
